20 Most Recent Canon imageRUNNER C6800 Copier Questions & Answers
E000820-0202-05
I am facing problem that error in canon imagepress c6010 E00820-0202-05 how to fixed it
11/29/2021 6:40:53 PM • Canon... • Answered on Nov 29, 2021
5answers
Error code E000013-0001
getfile.asp?rid=1258 February 2, 2005 getfile.asp?rid=3215 Product : imageRUNNER C5800 / C6800 Title : E013 code and Waste Toner Full message Question :
The copier shows an E013-0001 and "Waste Toner Full" message. The Waste Toner Bottle has been emptied and SW1 is operating properly but the code and the message are still appearing on the display.
Answer :
The counter for the Waste Toner Bottle needs to be reset back to zero in Service Mode.
Enter Service Mode level 1 by pressing * 2 8 *, select Copier > Counters > MISC, then highlight WST-TNR, press Clear - the counter will zero out.
Power off the copier, turn the copier back on, the Waste Toner Full message on the display should clear out.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
7/9/2019 2:16:14 PM • Canon... • Answered on Jul 09, 2019
Canon code e070-0000
Hi,I will suggest you reset your canon printer, Follow this steps to reset your canon printer.1. Turn off printer.2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.3. let go button Resume/Cancel, continuing to retain POWER.4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.6. turn off printer by button POWER. Power on later, that should fix the problem
12/11/2017 10:31:34 AM • Canon... • Answered on Dec 11, 2017
2answers
Error code E000006-0001
Please give the model and the make
10/29/2017 7:39:22 AM • Canon... • Answered on Oct 29, 2017
Manual ir c6800
e0000-0008
10/19/2015 3:23:18 AM • Canon... • Answered on Oct 19, 2015
2answers
I have a code E000013-0002
west tone tank full remove it & clean it
9/24/2015 7:43:17 PM • Canon... • Answered on Sep 24, 2015
3answers
CANON IR C6800 ERROR CODE E000078-0001
error code E000005-0000
6/12/2015 12:42:27 PM • Canon... • Answered on Jun 12, 2015
2answers
ERROR CODE E000540-8002
the motor in the upper tray of the finisher has locked up and is not moving properly. the motor needs to be replaced.
3/10/2015 6:29:24 PM • Canon... • Answered on Mar 10, 2015
Hi canon IR 6800 CN error code E000100-0002 this error
laser is faulty
11/10/2014 5:06:13 AM • Canon... • Answered on Nov 10, 2014
E000012-0001
The drum motor (M2) is faulty. The DC controller PCB is faulty.
11/10/2014 4:01:38 AM • Canon... • Answered on Nov 10, 2014
Canon imageRUNNER IR5800C E000100-0002 Error Code
CHANGE LASER OR USE RESET ONLY
11/10/2014 2:26:21 AM • Canon... • Answered on Nov 10, 2014
Xerox 6800 fuser reset
USE THE *28* COPIER> FUNCTION > CLEAR > ERR >OK SHUTDOWN AND OPEN
11/10/2014 2:21:15 AM • Canon... • Answered on Nov 10, 2014
Where is the tonor waste canon
TONER WASTE IS LOCATED AT BACK OF MACHINE, NEAR TO THE POWER SUPPLY. OPEN FROM SCREW DRIVER
11/10/2014 2:13:10 AM • Canon... • Answered on Nov 10, 2014
E000100 0002 ir 6800
INTERVAL ERROR, MEANING LAZER PROBLEM
11/10/2014 1:57:56 AM • Canon... • Answered on Nov 10, 2014
CANON IR6800
CLEANING WEB MUST BE CHANGE AND RESET
11/10/2014 1:55:04 AM • Canon... • Answered on Nov 10, 2014
Error code e-00732-0001
THE CONNECTOR WIRE FROM MAIN BOARD TO SCANNER IS FAULTY. PLUG CORRECTLY
11/10/2014 1:49:54 AM • Canon... • Answered on Nov 10, 2014
Shadow of copy in ir 6800
CHANGE OR CLEAN THE CLEANING BLADE ONLY
11/10/2014 1:41:41 AM • Canon... • Answered on Nov 10, 2014
Erro E000002
THE MAIN THERMISTOR (TH1) HAS POOR CONTACT OR OPEN CIRCUIT. THE THERMAL SWITCH (TP1) HAS AN OPEN CIRCUIT.THE SSR IS FAULTY.THE DC CONTROLLER IS FAULTY.
11/9/2014 5:32:00 PM • Canon... • Answered on Nov 09, 2014
3220N cannot open service mode with * 28 *
CLEAN YOUR KEYBOARD PANEL
11/9/2014 5:27:08 PM • Canon... • Answered on Nov 09, 2014
Canon ir 6800cn error code e00061
AS THE RESULT OF POTENTIAL CONTROL, THE DRUM SURFACE POTENTIAL (VL2) OF A WHITE BACKGROUND IS ABOUT 200V (GENERATING SOLID BLACK IMAGES)
11/9/2014 5:21:50 PM • Canon... • Answered on Nov 09, 2014
Canon imageRUNNER C6800 Copier Logo
199 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
error code e000100 0002
  • Office Equipment & Supplies
