20 Most Recent
Canon LV-LP12 Projector Lamp for LV-S1, LV-X Questions & Answers
Canon lv- x5
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
POWER SUPPLY PROBLEM
LV-S1 X1
power supply unit
price :USD70
Have a nice day!
Lampdeng Limited
Jerry
Rectification of Power Supply Unit of CANON Projector Model No : LV -S4 Serial No : T701182A
the power supply unit is USD60
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
CANON PROJECTOR LV-S4 POWER SUPPLY UNIT
power supply for S4 ,Unit price is USD65
have a nice day!
skype:lampdeng
Big Green Bar
Hi Tom017
Does this green bar show even when there is no signal inserted into the Projector ?
If it doesn't then you can try using a different cable - that should solve this for you.
If it doesn't then you might be in for a quite expensive Mainbaord repair or replacement.
Good luck and thanks for using Fixya !
My Canon LVS1 projector does
Check your setup options in the projector menu to be sure that you have Component Video enabled. It is possible that it is looking for another input.
My projector is projecting an
hi
this sounds to me like the projector lamp is coming to the end of its life. projector lamps last about 1000 hours of reasonable quality, but if it gets turned on and off regularly then that number will decrease.
you might want to buy a new lamp if there not to expensive or maybe to into having it refurbished.
also dirt in the projector can decrease brightness. so maybe you could see if the manufacturer will clean it for cheap
hope that helped
My Epson PowerLite 1725 projector
im afraid that sounds like some dead pixels. and if thats the case then no a bulb wont fix it. call epson tech support and see if they will replace it for free.
The projectors is working but
try cleaning all the projection lenses wipe it with a soft cloth.check also the color wheel whether the are projected in accurate color .make sure the wheel spins at constant speed with no vibration..you need to open the case of the projector.replacing a new lamp will also help..
Lv-s1 canon projector
Hi there
Open up the unit and replace the fuse on the Powersupply ( where the AC inlet sits )
If this doesn't do the trick you will have to replace the Powersupply itself.
But most of the time it is only the fuse that has gone.
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual
here if you don't have one. Instructions for cleaning the filters are on page 37.
Canon lv-s1
Update the problem in details. And you can get the same in canon authorized service center.
Regards,
prakasam
Help
Hi there
Sometimes the lamp gets stuck because of all the heat from the lamp. Simply take a small flat screwdriver and lift it out.
