20 Most Recent Lexicon LX-7 7-Channel Amplifier Questions & Answers
I had the same problem on my VTX65. I noticed it would oscillate with different effects so I removed the effects module. Problem solved. Now it's dead quiet. I use a Digitech RP500 so removing the effects module was a non issue.
Lexicon LX-7... | Answered on May 20, 2014
Hi chupetin2
If the problem is present with ONLY the speakers connected, that is no other powered devices like subs, or input/output cables, it will be a power supply problem inside the amp. If you have electronic fault finding skills, there will probably be a capacitor in a regulated rail that has failed.
If you do have a sub connected, be sure it is powered from the same mains source as the amp, or at least a GPO that is on the same phase. Different phases will induce mains hum, as will multiple earths. Try also temporarily moving the amp(whilst monitoring the hum) from where it is sitting and see if the hum is being induced into the amp by any other devices
Happy to talk to you more about this. Just ask:)
regards
robotek
Lexicon LX-7... | Answered on Aug 19, 2008
replace your hdmi cable between tv and preamp...lemme know if it works.
Lexicon Audio... | Answered on Mar 24, 2014
Hello Joseph, indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Joseph, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Audio Players &... | Answered 4 hours ago
Hi Ihtisham, indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Hola Ihtisham, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Audio Players &... | Answered 13 hours ago
You can view the manule here:
https://www.manualslib.com/manual/192102/Technics-Sl-Mc7.html#product-SLMC4%20-%20COMPACT%20DISC%20CHANGER
(I think they also let you download a PDF of it as well).
Audio Players &... | Answered 14 hours ago
the best video converter i have found is called Xylisoft media converter it has just about every type of video conversion that you could want to do
Audio Players &... | Answered 23 hours ago
If you did not backup your iphone with iTunes or iCloud , the recovery software for iPhone users may help you retrieve the deleted data, you can get them back in few steps.
Tips to Retrieve Deleted Voice Memos on iPhone 6 5S
Audio Players &... | Answered Yesterday
After connecting one, turn on the other. Then while both are powered on? Press and hold the button on both earbuds until they connect to one another.
Lexicon LX-7 7-Channel Amplifier Logo
3 questions posted
Top Lexicon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Lexicon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Lexicon Audio Players & Recorders
Most Popular Question
crate gtx 65 guitar amp mains hum
  • Audio Players & Recorders
