20 Most Recent
iRiver PMP-140 Digital Media Player Questions & Answers
Iriver PMP-140 boot failure message
when i turn on my Iriver PMP-140 it comes up with a message reading
Boot Failure
System file has an error.
To solve the problem, connect the device to computor.
(refer to 'trouble shooting' on the manuel)
Filmware Ver. 1.24
I dont have a manual though.
Boot failure
Here is the fix:
Boot Failure
Sometimes just downloading and following the procedure in
Boot Failure does not work, because the system files cannot be overwritten, in this case follow the additional instructions here to delete manually the system files.
PMP-140 Boot Failure
You might need to change your format from NTS something to FAT32. Hook up your iriver to the comp. and right click the iriver drive..scroll down to format and click the arrow to chang it. My brother told me how but i still haven't tried it yet b/c he said that i needed a older comp. to do it. but i believe it'll work once i have the option to choose FAT32.
My iRiver e200 does hang...and it displays "USB busy.. Do not Disconnect if I connect it to PC. And I cannot play my MP3s
Hi there! Well it sounds like the flash memory in your device has failed. This may not be the case. There is no way to say without testing and diagnostics, however if you can not access the files saved to the memory via the device(Playing the files) and the computer can not access that memory when connected, there is a strong possibility that your memory has failed. I am not sure the age of the device but it is well documented that all flash memory will at some point fail because it can only be read and re/written X amount of times(this is normal). Typically most devices will reach "EOL"(End Of Life), or end of use before the memory fails. The likely hood of recovering the files located within the inaccessible memory is very unlikely but may be possible. Replacing the memory chip in the device is possible but not feasible. I hope I have been able to help you today. Please if I misunderstood your question let me know so I can get you the appropriate help. Thank's Mr.Mike
