20 Most Recent iRiver iFP-380T MP3 Player Questions & Answers
0answers
0answers
I purchased an IFP-380t unit
Hi Eric..fHere is an easy way to delete your unwanted files
Deleting Files,Pictures,Videos,Audio Books, Apps,etc. from MP3 Player/Ipod
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Please take time to rate me
8/4/2011 12:26:26 AM • iRiver iFP-380T... • Answered on Aug 04, 2011
3answers
Driver
I found a Manual to help & a couple of driver links hope this helps... www.iriveramerica.com/download/iFP-300-Eng-Int-030403F.pdf www.driversforwindows.com/iriver_ifp_380t_firmware_1.22_21557.htm drivers.softpedia.com/get/FIRMWARE/Iriver/Iriver-iFP380T-firmware-122.shtml
1/2/2011 1:05:54 PM • iRiver iFP-380T... • Answered on Jan 02, 2011
My fiancee' jsut got an Iriver 380t, at a pawn
You can get it all for FREE, from the manufacturers web site below.
http://www.iriverinc.com/download/downloadList.asp?selectPart=cateCode&findWord=01
3/3/2010 10:57:50 PM • iRiver iFP-380T... • Answered on Mar 03, 2010
Music Transfer Problem
Make sure the songs are in the correct format - Mp3 would be best.
If they are all in the correct format, then reformat the player:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
2/18/2009 3:59:00 AM • iRiver iFP-380T... • Answered on Feb 18, 2009
Play mode
Check the manual.
6/26/2008 1:57:14 AM • iRiver iFP-380T... • Answered on Jun 26, 2008
IFP-395T (AA Batteries)
Probably a hardware issue, but the issue could also be with your USB port - make sure that there are no yellow exclamations next to the usb port in the PC device manager.
The battery indicator might not be stable during the following activities because they use large amounts of power:
1. The backlight of the LCD
2. Volume change
3. Pressing function keys and buttons
4. Reading the CD or files (Loading data to the memory)
The battery indicator shows the life expectancy of the battery based on current power usage. During these high power usage activities, that may only last a few seconds, the indicator will obviously show a lower level on the battery indicator. Once the high power activity has ended it will show a more accurate battery level.
6/23/2008 3:34:05 AM • iRiver iFP-380T... • Answered on Jun 23, 2008
IFP-380T MP3 Player Problem (doesn't turn it on)
Here's my shortcut:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Here is a suggestion from the iRiver website - you may want to visit that website, b/c their "Ask Alice" tech support feature is actually quite good:
The players come with a CD that contains drivers and software that enable the player to download data from a PC. Insert the CD in the computer's CD drive, and connect the player to the PC with the USB cable. (Help with USB cable connections) The PC should automatically detect the device. The New Hardware Installation Wizard will automatically launch and the installation process will start.
If the above procedure does not occur on your PC, please manually install the driver. Use the links below for instructions:
If you still have trouble, the issue may be with the computer chipset. iriver has tested many PCs and discovered that this only occurs in a small number of main boards.
6/23/2008 3:30:26 AM • iRiver iFP-380T... • Answered on Jun 23, 2008
Users manual for iFP-380T
try iriveramerica.com
2/13/2008 8:31:12 AM • iRiver iFP-380T... • Answered on Feb 13, 2008
When connecting iRiver Clix with computer, it charges only the battery. How can I put it in USB mode?
It is circa 2007 so probably looking Windows XP and Windows Media Player 11. Not compatible with your computer Operating System is the most likely reason. You may be able to force the computer to look for drivers. https://www.google.com/search?q=Iriver+clix ..
11/7/2023 11:31:31 PM • iRiver Audio... • Answered on Nov 07, 2023
iRiver iFP-380T MP3 Player Logo
Popular Tags
29 questions posted
Top iRiver Audio Players & Recorders Experts
SmartAviator
SmartAviator
Mohammad Abumuailek
Mohammad Abumuailek
ExpressFiX
ExpressFiX
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • iRiver Audio Players & Recorders
Most Popular Question
purchased ifp 380t unit
  • Audio Players & Recorders
