20 Most Recent
ALL LIVING THINGS Digital Thermometer & Hygrometer Questions & Answers
How do you use it
--- SCANNED INSTRUCTIONS ---
CLOCK AND DATE SETTING: 1. Press and hold MODE button for three seconds. The minutes display will begin flashing. Press MODE button to switch among minutes, hour, 12/24 hour, month and day. 2. Press ADJ button to set value of the minutes, hour, 12/24 hour, month and day. NOTE: Original screen will return after one minute of inactivity. To view the date, press ADJ button.
ALARM CLOCK SETTING: 1. Short press MODE button to switch from clock to alarm clock. 2. Press the ADJ button once to make the D))))) symbol appear, which will indicate that the alarm is on. Press ADJ button again and a bell symbol will appear, indicating hour notification signal is on. The hour notification signal
sounds once at the top of every hour. Press ADJ button again to activate alarm clock and hour notification signal, press ADJ button again to clear all.
MEMORY FUNCTION: 1. Press the MEMORY button for maximum temperature and humidity to display. Press MEMORY button again for minimum temperature and humidity to display. Press MEMORY button again to return to current temperature and humidity. 2. Press and hold MEMORY button for three seconds to clear maximum temperature, minimum temperature and relative humidity.
COMFORT DISPLAY: When temperature remains between 68F to 82F (20C to 28C) and the relative humidity remains between 50% and 70% "COMFORT" will be displayed. When relative humidity is above 70% "WET" will be displayed. When relative humidity is below 50% "DRY" will be displayed.
FAHRENHEIT/CELSIUS: To switch between Fahrenheit and Celsius, press FAHRENHEIT/CELSIUS SELECTOR button on back of unit.
INSTALLATION: 1. Use provided suction cups to position the sensor probes in the terrarium. 2. Position THERMOMETER & HYGROMETER in desired location outside of terrarium with a built-in stand.
BATTERY TYPE: 1 PC Button cell (AG13/LR44)
WARNING: Install THERMOMETER & HYGROMETER and sensor probe out of reach of pets and away from water.
For more information about All Living Things products, please call 1-800-806-7870.
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
How can I adjust the time on my weather station model #sgr72914?
- Access the Time Setting Mode:
- Locate the 'Set' or 'Settings' button on your weather station. This button is typically found on the front or the back of the unit.
- Press and hold the 'Set' or 'Settings' button for about 3 to 5 seconds. This action should access the time setting mode, where you can adjust the time.
- Adjust Hour and Minutes:
- Once in the time setting mode, use the 'Up' or '+' button to increase the hours and the 'Down' or '-' button to decrease the hours.
- After setting the correct hour, press the 'Set' or 'Settings' button again to move to the minutes setting.
- Use the 'Up' or '+' and 'Down' or '-' buttons to adjust the minutes accordingly.
- Confirm the Time:
- Once you have set the correct time, press the 'Set' or 'Settings' button again to confirm and exit the time setting mode.
- Check the Time Display:
- After setting the time, check the display to ensure that the time is displayed correctly.
My LM 30 laser won't start-has brand new batteries
1.Remove the batteries to determine if they have been properly installed in the unit. I know I've messed up installing multiple batteries is a unit. Ck just incase. :)
2.Then the battery unit can be removed 10 seconds to allow the capacitor to discharge and reset the unit.
