20 Most Recent
Canon MP-25DV Calculator Questions & Answers
How to set date and time on canon mp25dv calculator
How to Set the Time & Date for a MP25DV Canon Calendar & Clock Printing Calculator The steps listed in the Calculator Instruction Manual for the Canon MP25DV Calculator did not work. The correct steps for setting the time and date on this calculator are listed below: 1. Press the time/calendar button one to select the date mode. The display should show the month-day-year. 2. Hold down the = button until the month start flashing. 3. Use the number keys to enter the current date, month and year. Example 07-22-2021 4. Press the = key to set the current date. 5. Press the CE/C key to return back to the calculator mode. 6. Press the time/calendar button twice to select the time mode. The display show the hour-minute-seconds & time of day. Example 02-01-14 A 7. Hold down the = button until the hour start flashing. 8. Use the number keys to enter the current time. 9. Press the X button for (A) a.m. or (P) for p.m. 10. Press the = key to set the current time. 11. Press the CE/C key to return back to the calculator mode. 12. To check the current date and time on your calculator, press the calendar/time button once for date and twice for time.
How do you set the clock/calendar on the Canon MP25DV?
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button.
Then, press the calendar, clock key.
next, press the equal sign key until the date is flashing
type in the date using 11172006.
press the equal sign again and the date is set.
Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set.
to display the date and time when not using the calculator, press the calculator, clock key 2x's.
to go to compute mode press the red CE/C button.
