the most likely cause of this is that the laser lens or laser is defective or the circuit that controls the Disc read is defective, in any event the cost to repair it will exceed the cost to replace it, the shop rate for this type of problem is $80 per hour just to look at it, then u have to do the repair, so u end up with a bill that exceeds a new DVD player, i always advise customers against repair and just buy new unless it is a very expensive unit and is nearly new.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Question edited for clarity and add CAPS.
To update the software, it has to be connected to the Internet, and it sounds like there is no internet connection via the television, so it is looking for a USB Cable to a computer.
https://www.google.com/search?q=ematic+at103b+update+the+software+version
JustAnswer
https://www.justanswer.com > Ford Repair
Jun 10, 2007 - I need the wiring diagram for the factory radio on a 2005 GMC/Yukon - Answered by a verified Ford Mechanic.
1 answer · Top answer: Hi, beloware the diagrams, I had to break them up being they were so big, thanks ...
Pinterest · dominiquesawadogo
3 years ago
55 Luxury 2004 Gmc Yukon Bose Radio Wiring Diagram- Car radio installation trimmings comprise of harness adapters leads, fascia adapters, ...
JustAnswer
https://www.justanswer.com > GMC Questions
Feb 17, 2015 - I need the wire diagram for 04 Yukon with the Bose system the pin lay out that plugs in the back of the radio. Share this conversation.
1 answer · Top answer: Gary : Welcome! My name is ***** ***** I will do my best to assist you with this problem. ...
Potential causes and solutions:
High Contrast Mode:
Some TVs have a high contrast mode that can inadvertently cause the picture to appear negative or distorted.
Try this: Hold down the volume button on your Samsung TV remote and navigate to the settings related to contrast. Turn off the high contrast mode, and see if that resolves the issue.
HDMI Connection Issues:
A loose or faulty HDMI connection between your TV and an external device (such as a cable box, gaming console, or streaming device) can lead to color abnormalities.
Check the HDMI cable for damage and ensure it is securely plugged in. If necessary, try a different HDMI cable.
Additionally, an HDMI handshake failure during setup can cause color problems. Restarting both the TV and the connected device might help.
Picture Mode Settings:
Sometimes, the picture mode on your TV affects color accuracy. Modes like "Vivid" or "Dynamic" may exaggerate colors.
Switch to a more standard mode like "Standard" or "Cinema" to see if the pink tint disappears.
T-Con Board Issues (Specific to Some TVs):
If you have a Samsung TV, a polluted T-Con flat cable could be the culprit.
To address this, clean the contacts on the T-Con board using isopropyl alcohol. First, remove any dust. If unsure, consider seeking professional assistance
Unfortunately you will have to purchase a remote control for it. All menu systems are within the setup display, all of which are controlled with the remote.They may be available on eBay.Andrew found the link.
