20 Most Recent
John Deere Synchronizer 4010 4020 4030 4230 4320 4430 Questions & Answers
John Deere Gator xuv 550 starts but stalls... idles up and down.
Sounds like a bad carb. I would try cleaning with car cleaner first, follow up with a simple rebuild kit where you replace throttle needles, idler. Most likely caused by ethanol gas. it gum up the carb very easily and if you let the unit sit for any length of time it sure to happen. Make sure gas is ethanol free and use a stabilizer in the fuel if you are going to park it more than a week at a time.
12/21/2017 12:46:35 AM •
John Toys
Answered
on Dec 21, 2017
How to remove the bolts on the starter John Deere Gator 620i
This is what I did to remove starter on 620i xuv gator. Remove starter solenoid and use extension 3/8 drive with universal joint to remove top bolt or remove front half of plastic shroud over drive belt assy , drill hole into cover in line with top starter bolt, insert extension with socket onto top starter bolt. Be sure to cover drilled hole with suitable material.
8/14/2015 7:14:15 PM •
John Toys
Answered
on Aug 14, 2015
