20 Most Recent JNC Computers SSF-35 (512 MB) MP3 Player Questions & Answers
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
JNC Computers... | Answered on Mar 11, 2008
JNC SSF-22 instruction manual is not freely availableanywhere. You have to pay for this. If youagree to pay, then you can visit http://manuals-market.com/search.php?cmarque=PERFORMANCE%20TEKNIQUE&modele=ICBM%20779. Afterclicking this link you will be forwarded to a page contains a form. You need tofill up that form. Most of them are pre-filled. You need to write "JNC"in Brand box and model number in "model number" box. Please don'tforget to mention "media player" in the "description box".Finally accept their "terms and condition" and click on "search"tab. Downloaddocuments as per your requirement. Hope this will help you. Good Luck.
JNC Computers... | Answered on Sep 06, 2011
MP3 players can only play music files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
JNC Computers... | Answered on Apr 11, 2011
are your ear phones working at all? try them in something else (like the earphone jack on some computers or tvs)
JNC Computers... | Answered on Aug 18, 2009
Hi, there
Since your unit has a CD player, the problem with both the turntable and cassette deck is probably due to the rubber belts that turn both mechanisms losing elasticity or have broken over time (or in the worst case scenario, turned to goo). I don't know your model manufacturer, but turntables often have a clip, or some sort of apparatus, that you can remove to lift the turntable platter up and off. If you can do that, you will be able to see what shape the turntable belt is in. For the cassette deck, more intricate disassembly is required. Replacement belts for both can often be found on eBay or other online sources.I found a video for an ion turntable that might have a similar belt system.
Audio Players &... | Answered 3 hours ago
Hello Billy, obviously your STR-K502P, has problems in the main power supply, control you have to remove the cover and look for a fuse indicated as; F901 FUSE (6.3Amp / 125V) and fix it is burned, if so, before replacing it, you would have to get a lamp holder and an incandescent lamp of 200 watts, the old lamps that bring filament, and connect the cables of the holder lamp to the ends of the fuse holder, the lamp replaces the fuse (serial lamp), you connect the STR-K502P to the power network and turn it on, if the lamp turns on completely and stays that way, it is very likely that there are components damaged and are generating a short circuit, in this case I suggest you look for a specialized technical service
If, on the other hand, the lamp is turned on and off or the intensity of the initial flash is reduced, this would give a guideline that there is possibly no short circuit, you can test the operation of the STR-K502P in this situation, if you can hear it, then replace it the fuse, its value is 6.3 Ampere / 125Volts
Once this is done, do not use the STR-K502P, without first checking all the cables and connections of the speakers, corroborating that you do not have any short circuit in them
I hope you can solve it
Greetings Franco Dosil
Hola Billy, evidentemente tu STR-K502P, tiene problemas en la fuente de alimentaci?n principal,controla tienes que sacar la tapa y buscar un fusible indicado como; F901 FUSE de (6.3Amp/125V) y f?jate se esta quemado, de ser as?, antes de reemplazarlo, tendr?as que conseguir un porta lamparas y una lampara incandescente de 200 watts, las viejas lamparas que traen filamento, y conectar los cables del porta lampara a los extremos del porta fusible, la lampara reemplaza al fusible (lampara serie), conectas el STR-K502P a la red de energ?a y lo enciendes, si la lampara se prende por completo y se queda as?, es muy probable que haya componentes da?ados y est?n generando un cortocircuito, en este caso te sugiero que busques un servicio t?cnico especializado
Si por el contrario, la lampara se prende y se apaga o baja la intensidad del encendido inicial, esto dar?a pauta que posiblemente no hay corto circuito, puedes probar en esta situaci?n el funcionamiento del STR-K502P, si logras que puedas escucharlo, entonces reemplaza el fusible, su valor es 6,3 Amper/ 125Volts
Hecho esto, no utilices el STR-K502P, sin antes controlar todos los cables y conexiones de los parlantes, corroborando que no tengas alg?n cortocircuito en ellos
Espero que lo puedas resolver
Saludos Franco Dosil
Audio Players &... | Answered 6 hours ago
Lorraine McKellar wants answers to this question
Hi Lorraine, I sent you the link so you can get the DVB-T202 user manual
Hola Lorraine, te envio el link para que puedas obtener el manual de usuario del DVB-T202
https://data2.manualslib.com/pdf3/79/7820/781968-august/dvbt202.pdf?25f00993f17422491b49e230e03de502&take=binary
Audio Players &... | Answered 21 hours ago
JNC Computers SSF-35 (512 MB) MP3 Player Logo
5 questions posted
Top JNC Computers Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a JNC Computers Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JNC Computers Audio Players & Recorders
Most Popular Question
mp3 doesnt play music
  • Audio Players & Recorders
