20 Most Recent UNO Moo - Barnyard Farm Animal Pre-school Matching Game Questions & Answers
Lost our rules/instructions on UNO Moo-Barnyard
moz-screenshot.pngYou can find the directions here
http://service.mattel.com/us/product_detail.asp?id=N7793&Ntt=N7793&Pn=1&Brand=Mattel+Games+and+Puzzles&Cat=UNO
8/18/2011 5:29:24 PM • UNO Moo -... • Answered on Aug 18, 2011
I lost the directions, can
Hello.
You can download the complete manual/instruction by clicking the link below:
Uno Moo
After opening the link above, click "To download manual, click HERE"
Thanks for using Fixya!
Please rate my answer.
8/11/2011 1:05:03 PM • UNO Moo -... • Answered on Aug 11, 2011
0answers
0answers
Uno Extreme Card Launcher. The wheels are not turning to spit cards out.
Contact Mattel for warranty replacement. Did you put 3 x C size Alkaline Batteries in it? https://www.manualslib.com/manual/2144497/Mattel-Uno-Extreme.html https://www.google.com/search?q=uno+extreme+wheels ..
12/30/2023 6:11:38 PM • UNO Toys • Answered on Dec 30, 2023
2answers
I need a copy of instructions for how to play UNO and I need it in Spanish.
The instructions for most Mattel games are available here: https://service.mattel.com/us/instruction_sheets.aspx . The direct link to an instruction sheet for UNO with both English and Spanish is https://service.mattel.com/instruction_sheets/UNO%20Basic%20IS.pdf . The Spanish rules are on the right hand side of the page. I hope this helps. Cindy Wells
10/5/2023 9:39:38 PM • UNO Toys • Answered on Oct 05, 2023
I have lost instructions for playing uno flash
Requirements
  • 2 to 6 players
  • An Uno Flash playing unit
  • An Uno Flash card deck
Setup Shuffle the deck and deal 7 cards face down to each player. Place the rest of the deck aside. On the underside of the unit, set the turn timer switch to the desired length--this can be 4, 6, or an infinite amount of seconds (designated by the infinity symbol). Beginners may find that 6 or the infinite amount of seconds may be most appropriate. Switch the power to "1" or on, also found underneath. Place the rest of the deck in either of the basins in the unit. This will be the draw pile. Flip one exposed card into the empty basin as a starter card. Once the unit has been powered on, each player participating must press one of the 6 red buttons found around the circumference of the unit. A player should pick the one closest to them to avoid confusion with other player's buttons. These buttons will designate each player's turn for the remainder of the game. Press the small yellow "Play/Pause" button to start the game. Play Immediately, players will notice a random selection of one player. This player will be designated by the lighting and flashing of their button. Note that there is no uniform turn order; the device picks a player at random each turn, including the same player of the last turn. At this point, the chosen player must make a play based on the most recently exposed card. To make a play, a player will either discard a card into the exposed basin on the unit, draw cards from the draw pile, or may be skipped. These plays vary with each type of card, and will be explained. Once a play has been made, that player must tap their red button to complete their turn. Plays must be made before a player taps their button. If a player fails to make a play before their time is up, their play must be forfeited and that player must draw 2 cards. That player cannot discard for this turn. Players will know when a player has not made a play in their allotted time when their button is flashing and an alarm sound is emitted from the unit. Plays must be made before a player taps their button. Once the player has drawn their two cards, that player must resume play by pressing their red button. Card Types and Sequencing As with most types of Uno games, cards may only follow one another if they match in color and/or number. Special cards such as slap, skip, and draw cards may be played after the same type of special card or a card of the same color. For instance, a player may play a blue skip card after a yellow skip card. Normal cards may be placed after special cards if they match in color. Wildcards may be played at any time. The following section explains the types of cards found in Flash Uno:
  • +2 draw card
Indicates that the next player chosen must draw 2 cards and may not discard. The next player may avoid drawing two cards by placing another +2 (or +4) card during their turn. In this case, the cards to be drawn are delegated to the next player, unless of course, they also play a draw card. For instance, if two +2 cards are played in a row, the next player must draw the total of 4 cards.
  • Slap or hand card
When a player plays a slap card, he or she should not press their red button to complete their turn. Instead, after placing a slap card in the basin, that player should press the yellow "Uno" button on the unit. This will start a race between the other players. After the "Uno" button has been pressed, the other participating players must race to tap their red buttons. The last player to do so will be indicated with a flashing red button. This player must draw 2 cards, and press their button to resume play.
  • Skip card
A skip card indicates that the next player chosen may not discard a card. They are skipped from their turn. The skipped player must press their button to resume play.
  • Wildcard
A wildcard may be played on top of any card. Once discarded on to the exposed pile, that player must verbally designate a new color for the next turn.
  • +4 Wildcard
A variant of the wildcard and the +2 card, this card allows the discarding player to specifiy a new color and require the next player to draw. Since the next player is only picking up cards, the new color must be played by the following player.
  • Normal Numbered Cards
Normal numbered cards are the most common card, and do not require any special actions to be taken by other players. Win Condition Players may win the game by becoming the first to discard all of their cards. Before winning and when a player has only one remaining card, that player must continue in typical Uno fashion and say "Uno" to the other players. This should be done immediately after discarding one of two remaining cards. If another player notices and says this first, the player with one card must draw 2 more cards in penalty. Strategy New colors after wildcards should be chosen based on the discarders most common color. Other Features and Information Players may pause the game at any time with the small yellow "Play/Pause" button on the unit. This can be useful when one or more players cannot play for a small amount of time, such as a phone call. You can evaluate how much time is remaining in a turn based on the rotating yellow lights on the unit. Each revolution indicates 2 seconds. For example, with a 6 second turn time, the lights will oscillate 3 times.hope this help..... enjoy the game.....
10/2/2023 12:53:53 PM • UNO Toys • Answered on Oct 02, 2023
My uno cards and tink fell apart
Contact Mattel for a replacement. https://www.google.com/search?q=Uno+Attack ..
12/10/2022 2:46:00 AM • UNO Toys • Answered on Dec 10, 2022
0answers
What does eplurbus uno mean
Latin for "out of many one"
6/1/2015 12:49:26 AM • UNO Toys • Answered on Jun 01, 2015
0answers
0answers
0answers
2answers
Lost instructions for uno extreme
You can looking in the this link about Demo_Rules or also can find it in Rules UNO Attack (pdf)
I hope help with this (remember to rate this answer).
1/4/2012 5:35:10 PM • UNO Toys • Answered on Jan 04, 2012
Are you allowed to pick
You can, but if you already have a card you can play, you should play it. The card you pick up may not be what you want.
8/14/2011 9:41:35 PM • UNO Toys • Answered on Aug 14, 2011
UNO Moo - Barnyard Farm Animal Pre-school Matching Game Logo
10 questions posted
Top UNO Toys Experts
ADMIN Andrew
ADMIN Andrew
Bilal Ahmad
Bilal Ahmad
Level 1 Expert
Are you an UNO Toy Expert? Answer questions, earn points and help others
View Most Popular
UNO Toys
  • UNO Toys
Most Popular Question
lost our rules instructions uno moo
  • Toys
