20 Most Recent Casio WVA105HDA Wave Ceptor watch Questions & Answers
I have just purchased a Casio wave ceptor WVA105H
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
12/14/2016 9:16:37 AM • Casio WVA105HDA... • Answered on Dec 14, 2016
How to set a casio watch
http://support.casio.com/storage/en/manual/pdf/EN/009/qw2735.pdf
8/30/2015 4:47:22 PM • Casio WVA105HDA... • Answered on Aug 30, 2015
I have a disallignement of 10 minutes between the digital and the analogical time. The digital time is perfect how can I allign the analogical one?
You have to know that analog time "follows" digital time.Any hour/minutes correction on the display has direct effect on time/minutes hands.Some times, mostly after battery replacement,hands might have declination.That is why there is a function so called "Hands home position adjustment".Using this function you can align both hands to 12/00 position.If there is any declination (I think is your case) you can correct.Try to enable this function by pressing for 4-5 sec the upper left button(A) until "HAND SET" appears.If hands are not aligned exactly to 12/00 position, you must correct by pressing the lower right button (D) for forward movement or the upper right button (B) for backward movement.In fact, minutes hand is aligned,hour hand follows.When both hands are set to 12/00 (home position) press button A again.Time Mode returns to the display.Normally hands will now show exactly according to digital (display) time.I hope this will help.
5/23/2015 8:00:18 PM • Casio WVA105HDA... • Answered on May 23, 2015
0answers
Alarm time sounds 2 hours before
Is digital diplay shows your local time?
1/28/2014 12:17:29 PM • Casio WVA105HDA... • Answered on Jan 28, 2014
How to set time on wave ceptor wva 109hu
go to the link below to download the manualhttp://world.casio.com/wat/download/en/manual/
10/30/2012 2:28:20 PM • Casio WVA105HDA... • Answered on Oct 30, 2012
Wva-105h watchbands
company only place
2/2/2012 3:46:59 PM • Casio WVA105HDA... • Answered on Feb 02, 2012
0answers
I can't reset the Time.
browse through my tips and you will find link for all Casio watch manual downloads.
10/1/2010 10:28:57 PM • Casio WVA105HDA... • Answered on Oct 01, 2010
3answers
Changing time wva105h
same problem i opened the back of the watch very eazy just 4 srews. And moved the hands to my time zone hope this helps you. now i have to do the alarm it keep going off a 3 pm every day i feel that will be much harder.
9/12/2010 12:02:55 PM • Casio WVA105HDA... • Answered on Sep 12, 2010
I just replaced the battery and now it won't let
mcdevito75 here, If you replaced the battery yourself you may have moved the quatrz movement and mis-aligned the buttons the thier contact spot on the quartz movement. You"ll have to open the back nd check by pushing gently on each button 1 at a time to make sure each button is makeing contact at the right spot on the quartz movement, also even if the battery is new it can still be weak or dead as they have a shelf life, also you may need the exact battery number Casio recommends, a small watch repair shop in your area can advise. The 2 buttons you need to set your watch are MODE and SET. --------- Press and maybe hold in the MODE button, 2--3 seconds, MODE button usually on the right side of watch caseing, see the display flashing, now press set to set each function, (hour, minute etc.) press MODE after ecah function is set, (hour, minute etc.) once everything is set, press MODE again to see steady display.
7/21/2010 9:39:38 PM • Casio WVA105HDA... • Answered on Jul 21, 2010
Does not start after battery change
mcdevito75 here, Return your watch to whoever replaced the battery for adjustments. ------ If you replaced the battery yourself, you may have mis-aligned the buttons that press against the quartz movement to change the display, you"ll have to go inside the watch and make sure the buttons are touching where they are suppose to. It"s also ossible your new battery is weak from a long shelf life. Here also is Casio contact number, 800-706-2534 Optn. 2
7/13/2010 3:46:48 PM • Casio WVA105HDA... • Answered on Jul 13, 2010
Casio WVA105HDA Wave Ceptor watch Logo
51 questions posted
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Ceptor Casio
  • Ceptor Casio
Most Popular Question
reset time
  • Watches
