20 Most Recent Casio W752V3AV men's watch Questions & Answers
Lost manual for casio W752 watch and need to set
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download your instructions.
8/31/2010 3:50:31 PM • Casio W752V3AV... • Answered on Aug 31, 2010
I live in the east and my watch didn't change with
because u live in a dark lonely house
11/7/2009 2:32:51 PM • Casio W752V3AV... • Answered on Nov 07, 2009
Can i dive with this watch?
You definetely CAN NOT dive with this watch. It is good for swimming and snorkeling only. Real divers watches withstand at least 200 meters of depths and are specialy designed for it.
One of the best affordable divers watch manufacturers novadays is Seiko. Check Seiko website and learn about divers watches and all the features they have. List of waterproof markings and explanations are also available.
Do not forget to rate, please.
2/13/2009 6:50:59 AM • Casio W752V3AV... • Answered on Feb 13, 2009
AQ150W
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT DON'T FORGET TO RATE;
1/30/2009 1:19:18 PM • Casio W752V3AV... • Answered on Jan 30, 2009
4answers
Product came with no instructions
duplicate post - go to this thread http://www.fixya.com/support/t136982-no_instructions :)
8/28/2008 8:35:29 PM • Casio W752V3AV... • Answered on Aug 28, 2008
Casio Altimeter watch, no instructions
I was just gifted an old casio pathfinder model 1675 with the manual.
when inserting a new battery.....step #4
AC (AC CLEAR) touch the AC contact and the battery +(positive) side with metal tweezers for about two seconds.
Contacting the AC (all clear)is necessary when a new battery is installed to clear the previous memory to avoid erratic display..
I am going to get a new battery for it soon I want to play with it....and figure out how navigate through the functions.
oh yah......the pictures are extremly small but the AC contact point is apparently marked? inside the case obviously next to the battery close enough for the needle nose tweezers to reach each contact. I havent unscrewed my case yet, I want to have everything I need at hand like the battery before I dive into this thing. I dont mean to dumb it down, I was trying to keep it simple as the manual is 55 pages and a little confusing. I hope this helps the battery problem. I will try to delve into the reset problem from the other post..each function appears to have a reset option ......maybe crack the case open and try the new battery all clear thing with tweezers...maybe this would reboot so to speak the entire watch , being mine does not work and have only had it in hand for two hours I am pretty clueless, I was looking for how much the watch costs...i didnt relize it was a fairly old model, the new ones with the compass look very cool. anyhow goodluck
7/25/2008 5:54:49 AM • Casio W752V3AV... • Answered on Jul 25, 2008
5answers
No instructions
Go to this link armed with the four number module code from the back of the watch; http://world.casio.com/wat/download/en/manual/ Hopefully they will have a user guide for your watch. Hope this helps :)
11/27/2007 10:14:03 PM • Casio W752V3AV... • Answered on Nov 27, 2007
Casio wave ceptor wvq 202hdu ibver
I don't have wvq 202hdu but I have a waveceptor that had the same problem. After not being able to find a solution online, I went back and started playing with it and I figured it out on my wva-430a. Hopefully my instruction helps:
The problem is that the daylight saving time is set to ON (or maybe OFF) whereas it has to be set on Automatic (A). To change that on my wva-430a, I held the "Adjust/Display" button for three seconds. It showed "US 60" for me. Then I used the "Mode/Select" button to go to the next screen which shows CHI for Chicago (Central Time). Here you have to choose the city that corresponds to your time zone. Again by pressing "Mode/Select" it took me to the next screen which was the daylight saving option. The choices were ON/OF/A that could be cycled by pressing "Receiving/Set+" button. Set it to "A" for automatic. Then press Adjust/Display to see the last option for 12H/24H setting. Press Adjust/Display one more time to go out of the settings menu. Your watch should adjust itself immediately.
11/13/2007 6:54:14 PM • Casio W752V3AV... • Answered on Nov 13, 2007
My Casio digital watch changes the date at 12 noon rather than at midnight. The model is 5479. How can I solve this issue?
Time is not set correctly. You set the time as AM instead of PM and vice versa. Use the following manual to set time correctly. QW-5479 (casio.com)
12/31/2023 10:43:33 AM • Casio Watches • Answered on Dec 31, 2023
Why does everything equal zero when hitting EXE on
You may find a solution here:
If it does not work, use casioworld button on same page as it may help.
Rate me, please.
12/20/2023 1:53:16 PM • Casio Watches • Answered on Dec 20, 2023
Casio Analog MTP-1216 Watch. How do I get the pressure back off the 1216 Casio please?
Question edited for clarity. Question moved to Casio Watch, from Office Equipment. Pressure backs need a tool to unscrew the back and the gasket should be checked and greased. Best advice here https://www.fixya.com/support/r27181038-changing_watch_batteries ..
11/11/2023 11:54:03 PM • Casio Watches • Answered on Nov 11, 2023
My Casio Sea Pathfinder SPS-300 2572 functions perfectly except for no sound. I know when I set an alarm it does trigger because I can see the Alarm Icon flashing. Why is there no sound? Thank you
It is likely that the battery is depleted sufficiently that the sound feature can't work. Take it to a local jeweler for battery replacement service. https://www.fixya.com/support/r27181038-changing_watch_batteries ..
10/20/2023 3:16:08 AM • Casio Watches • Answered on Oct 20, 2023
Re Casio Waveceptor watch
limited info generic answer if its the lower $ end units-- pop off the back --and remove internals careful of springs for buttons --check for debris -failed spring-button bi-metal fail /damaged
8/23/2023 6:38:11 PM • Casio Watches • Answered on Aug 23, 2023
2answers
How to fix Quartz on my casio 708 mtp 3036
This is a job a specialist watch repairer should do. It will need specialist tools so if you are not familiar with working on watches pay someone to do it for you. Also consider the cost of repair. It might be cheaper to simply buy a new watch.
5/17/2023 6:49:58 AM • Casio Watches • Answered on May 17, 2023
Hoe kan ik een handleiding vragen van Casio. No.3464. Heb een Casio horloge gekocht maar is geen Nederlandse handleiding bij?
Question edited for clarity and spelling 'casino' to 'Casio'.Question Translated to English. We are a North American website.Question moved to Casio Watch category.https://www.google.com/search?q=casio+watch+netherlands..
4/23/2023 4:33:23 PM • Casio Watches • Answered on Apr 23, 2023
I recently changed the battery
There is a 437 stamped into the back of the case for one of the two versions (437 and 438) of Casio WR watches, with the 437 being the kind with raised rubbery number buttons. The model no. for the 437, also on the back case is CA-53W, useful for ordering parts (see below). These instructions are for the 437 but should be useful in many cases for other Casio watches, with numbers other than 437 or 438 on the back of the case. For example, the resetting process described in step 5 below appears to be common to many if not all Casio watches. There is no manual on the casio.com website for many watches, including the 437 and 438. There are no instructions for changing the watch battery in the manual for the 437 or 438 either, nor for many if not all Casio watches. If there is a 438 stamped on the back of the case, the chip is the same as on the 437. The buttons on the face of the 438 watch are flat plastic rather than raised and rubbery. The two buttons near the top serve the same function on the 438 watch as the right side buttons on the 437. The left top button on the 438 corresponds to the top right side of case nonindented button on the 437. The right top button on the 438 corresponds to the bottom right side of case lower indented button on the 437. Save time and money by replacing the battery yourself If you send your Casio watch off to have the battery replaced, it will likely cost you about $30 USD. Many jewelers will routinely send a Casio watch off for battery replacement rather than replace the battery themselves, so these instructions may help save you from delays and expense if you do it yourself. Likewise, jewelers may find these instructions useful for satisfying customers by replacing the battery on the spot rather than having to send the watch off to Casio. Materials needed a. 5/64" Phillips head screwdriver (A set of different size screwdrivers in a small black plastic case, including the 5/64" was bought for $1 USD at a local Dollar Tree store in the USA.) b. Watch battery identically numbered to the dead battery on the watch (2016 on 437 case back number) c. Metal tweezers to reset the watch d. Sil glyde gel grease or any other grease, to maintain water resistance f. Toothpick or similar to spread grease in O ring slot g. Ziplock plastic bag or bowl to hold the 4 small screws so they don't get lost Instructions on replacing the battery and resetting the watch 1. Take off 4 back screws, using the 5/64" Phillips head screwdriver. One screw was balky and needed to have the screwdriver handle attached to a vise grip pliars, with the watch held in the other hand and rotated. Putting the screwdriver handle in a vise would also work to stabilize the screwdriver, while turning the watch held in one hand. Set the 4 small screws aside in a ziplock bag or bowl. 2. Remove the red cellophane cover on the battery, held by two tabs cut into the cellophane fitting into a slot on the metal hold down battery strap atop the battery. 3. With a fingernail or toothpick (nothing metal), slide the battery to the side, out from under the metal hold down strap atop the battery. 4. Insert new battery with fingers/fingernails, sliding it into place from the side. The side, with the battery number showing (2016 on 437 case back number) faces outward, just as on the removed battery before it came out. The watch will continue to appear dead, with nothing showing on the display until the electronics are reset in step 5. 5. Reset the electronics by using a pair of metal tweezers to simultaneously touch with metal, the outward facing side of the battery, and the brass terminal in an indentation in the plastic about 4 o'clock and about 1/8" outside the battery diameter. To aid in orientation, there is a barely visible small AC (presumably meaning "all clear") pressed into the metal near the battery and the indented brass terminal at about 4 o'clock. It may be necessary to tilt the watch in the light so the light strikes the AC so it becomes visible. Verify the display is working. Resetting the time will be in step 11. 6. Reinsert the red cellophane cover removed in step 2. It may be necessary to slide a knife or similar between the strap holding the battery down, and the battery, to make room for the two cellophane tabs to be inserted in a small air space between the strap and the battery. (When installed, the cellophane tabs do not prevent current from flowing between the top of the battery and the battery hold down strap.) If you use a knife or other metallic object to open up the strap to battery space to allow entrance of the cellophane tabs, take care not to short the battery against metal parts of the watch other than the hold down strap. Quickly glance to see make sure the display is still working after the cellophane is back in place. If display not working, repeat steps 2, 5 and 6 (remove cellophane, reset watch, reinstall cellophane). 7. Remove the rectangular O ring from the case back removed in step 1, or the case, and coat it with Sil Glyde silicone gel grease or similar, to retain water resistance. White grease or any grease should also work. Set the coated O ring on the inside of the metal case back removed in step 1. The O ring will eventually mate back with the O ring slot in the plastic case. 8. Using a toothpick or similar, coat the rectangular O ring slot in the plastic case with the same grease used to coat the O ring in the metal case back, to provide extra water resistance. Grease is nonconductive, so there should be no damage from shorting if some of the grease gets inside the watch. 9. Wipe hands clean and wash hands and/or use plastic gloves to avoid putting too much grease on the outside of the watch. 10. Replace case back removed in step 1. Screw in the 4 removed screws with your 5/64" Phillips head screwdriver.
2/27/2023 1:32:07 PM • Casio Watches • Answered on Feb 27, 2023
Casio W752V3AV men's watch Logo
12 questions posted
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Casio Watches
  • Casio Watches
Most Popular Question
lost manual casio w752 watch need set
  • Watches
