20 Most Recent
Dymo LabelWriter 400 Thermal Printer Questions & Answers
Address book
Where's the address file located. You need to have full rights (Read, Write, File Scan, Modify, Delete, etc) to the Address file. Right-click on the file name, select Properties, view the rights you have to the file.
Printing blank labels
I am having the same problem! Printing blank labels. Don't know what's wrong now. It was working fine yesterday.
It begins to print then stops half way
Having the same problem here... very random... send a print job of labels and it will print the whole lot, or freeze at random points but always halfway through a label... no error message... unplug usb and replug doesnt do anything, but unplug and replug power and off it goes printing more lables but may even freeze again after only a few more have come out... also, every day the first print job of the day prints half the label and pauses for about 10 seconds then keeps going...
- Windows XP Pro SP3
- LabelWriter 400 as supplied out of the box
- Genuine DYMO labels
My Dymo Labelwriter 450 turbo feeds out 4 labels
Multiple label feeding usually occurs because the sides of the spool holding the roll are not squeezed tightly together. Make sure there's no gap between the labels and the sides of the spool. If this doesn't help. take out the labels and blow a blast of air into the feed slot. There is a sensor inside the slot on the left that detects the hole in the labels, and maybe it is blocked.
