20 Most Recent Jolly Jumper Babys Folding Insect Tent for Protection Against Bugs & Insects Questions & Answers
no idea what this asks?????
Home | Answered 14 hours ago
go to a place that sells them and ask for assistance . many have a cover over the screws that just pops off
Home | Answered Yesterday
POSSIBLY PLUMBER FORGOT TO PUT IN THE ONE FOR AIR HAMMER NOISE .
try your local stove shop , or a glass replacement company
Home | Answered 2 days ago
my ex wife had one of these and swore by it but that was nearly 30 yrs ago ,i bought it for her actually if i remember rightly ,and hers went wrong on a camping holiday with same sort of fault ,i took the end off and then used a primus stove pin to clean the end of the jet out ,its as small pin on a stick for cleaning camping stove jets ,worked fine after that but it always seemed to cog up after a year or so though ,wonder if the toy boy she ran off with could repair it for her
Home | Answered 3 days ago
On the back of the clock movement is a serrated little wheel, turn that.
Home | Answered on Apr 10, 2019
It gives the sign that the Fire Alarm is not of good quality, sometime it start beeping without any reason and sometime don't when needed. So, before buying any appliances make sure it is of good quality through its review and updates. Always buy Fire alarms from a good company or a place like Prelude Fire Alarms Ltd. I have experience from this for a long time and still does not face any miss happen.
https://www.prelude-alarms.co.uk/
Home | Answered on Apr 08, 2019
You need to remove the top from the tap that is stiff, this is normally done by removing a cap or plug from the top of the tap using a small screwdriver or some other form of lever, underneath you should find a screw, removing this screw should allow you to remove the tap handle/knob.
You should now be able to see the main shaft of the tap, where you have just removed the screw from. work down this shaft and you come to a nut, this is known as the packing nut, it places pressure on a seal to stop water coming back up the side of the shaft. It may be that this nut is a little too tight and is acting like a brake, you need to loosen this nut (anticlockwise) but not too much that water is allowed to seep out from the shaft, try a little at a time, (you also need to hold the bigger, lower nut to stop this turning) It could also be that lime-scale has formed on the bottom of this shaft, if this is the case you may need to replace this part of the tap, the bigger nut further down the shaft allows you to unscrew (anticlockwise) the tap from the main body and replace this part.Remember to turn off the water at the mains shut-off before removing the tap body. If replacing the tap body it needs to be tightened down to prevent it turning when turning the tap on and off.
Home | Answered on Apr 07, 2019
Jolly Jumper Babys Folding Insect Tent for Protection Against Bugs & Insects Logo
0 questions posted
Top Jolly Jumper Home Experts
Donni Steen
john h
Are you a Jolly Jumper Home Expert? Answer questions, earn points and help others
View Most Popular
Jolly Jumper Home
  • Jolly Jumper Home
Most Popular Question
water pipes in shower scream when turn
  • Home
