20 Most Recent Casio Sea Pathfinder Triple Sensor SPF-60 Questions & Answers
FLASHING RECOVER
Hello!I replaced the battery on SPF-60D. I reset the AC but now my pressure sensor is not working. It shows dashes ------ and when I go to the calibration settings it is OFF and I can't change the value. The temperature work OK. I'm asking for help!
9/1/2021 5:08:40 PM • Casio Sea... • Answered on Sep 01, 2021
Casio sea pathfinder sp60d reset
Hello, You need to open the watch and cortocircuit 2 points into the watch machine. TicTacArea.com is Officla Casio Dealer Casio Watches
8/20/2014 6:48:56 PM • Casio Sea... • Answered on Aug 20, 2014
I have a Casio Pathfinder 2805. The glass display screen is dirty on the inside. How do I remove the display screen to clean the inside?
Question edited for clarity. Question moved from Casio Business Machines. It is a job best left to a local jeweler when it is battery change time. The fact is got dirty inside means there must be damaged gaskets. If you want to do it yourself, remove the back and lift the movement out, being careful to not damage the button contacts. https://www.google.com/search?q=Casio+pathfinder+2805+remove+movement ..
4/9/2022 11:42:29 PM • Casio Pathfinder... • Answered on Apr 09, 2022
How to reset 2872 casio ?
If a Casio watch has a display readout that says "OPEN", the watch isn't closed properly. Check if all the parts are inside the watch and make sure the watch is tightly screwed shut. If the watch was serviced at a repair center you should return it to have it checked (for missing parts).
3/24/2015 3:42:40 PM • Casio Pathfinder... • Answered on Mar 24, 2015
How do set Casio model 6054 gw1000b
On the Casio website, this model 6054 isn't recognised. With the module number (you'll find it in a small rectangle on the back of the watch case) you can download the manual for your watch here: Timepieces Watches Manuals CASIO
3/24/2015 3:16:01 PM • Casio Pathfinder... • Answered on Mar 24, 2015
0answers
0answers
After 5 days of darkness, watch will not turn back on
The watch has a rechargeable power cell inside the cover. Remove the back, find the button batter, and replace it. It may be the old original or dead cell. Once you replace the cell, the watch will refresh and be back to normal. The only problem if that fails, the mini-computer brain died.
12/25/2013 3:12:33 AM • Casio Pathfinder... • Answered on Dec 25, 2013
Change time
What model Casio watch?
11/12/2013 12:32:30 AM • Casio Pathfinder... • Answered on Nov 12, 2013
Casio Sea Pathfinder Triple Sensor SPF-60 Logo
14 questions posted
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Pathfinder Casio
  • Pathfinder Casio
Most Popular Question
flashing recover
  • Watches
