20 Most Recent
JVC Sirius KD-LH300 CD Player Questions & Answers
How do u use the
First of all, thank you very much for choosing FIXYA today for your online technical support needs.See page 15 of the manual for detailed instructions about playing MP3 discs on that machine.
Here is a direct link to the ONLINE USER'S MANUAL for that model:http://resources.jvc.com/Resources/00/00/95/GET0201-001B.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
How do i set the clock
First of all, thank you very much Eileen for choosing FIXYA today for your online technical support needs.See page 9 of the manual for detailed instructions on how to set the clock on that device.
Joe.
I have a jvc kd-lh300
It sounds like you may have a bad internal output ic. If you know how to access the menu, some decks now have the option to turn off the internal output ic. I'm not familiar with that particular deck, so I couldn't tell you for sure.
No illumination on display when
If you can hear the cd player boots up then that it a confirmation that your unit has power. If the display don't light up, then the problem is a contact point in the face itself. If you know ow to take off the face and clean and align the contacts, test if it resolves your problem. If not, the only way to know for sure is to find a local car audio shop that's a JVC dealer, see if you can get a new face or if they are aware of the problem, I'm sure a shop may even keep those replacement faces in stock.
Hope this helps
By pushing the button to
is there a flexible cable going from the face to the main motherboard? if so, the cable may be bad.
Reseting P21 ?
Just unplug the power source to the Radio from the back
JVC KD-LH300 Display
Sounds like the problem is a contact point in the face itself. The only way to know for sure is to find a local car audio shop that's a JVC dealer, see if you can get a new face or if they are aware of the problem, I've answered this question a few times so I'm sure a shop may even keep those replacement faces in stock. Hope this helps
How do you get the sirius radio hook up to be
If you have all the devices hooked up correctly using the JVC/Sirius interface. It does not recognize it if it's defective. Most common problem sirius/xm has. The miniport for the antenna connection has a bad solder joint and thus is inop. if it does turn on by chance, it will say "acquiring signal" and that's it. If it's new get it replaced. If it was working prior to this, and it's out of warranty, go on Ebay and get a rebuilt tuner, their about 50.00 and more reliable than new. Hope this helps
Volume/Power
this could be a connection issue. are all wires tapes up with out touching each other? it could also be that you are trying to power too many speakers. u migth need a amplifier...
