20 Most Recent JVC PD-42WV74 42 in. Plasma EDTV Questions & Answers
0answers
LED8003
Be the first to answer 11/7/2017 5:54:04 AM • JVC PD-42WV74 42... • Posted on Nov 07, 2017Be the first to answer
JVC PD-42WV74 Plasma will not power on ?
I believe that this monitor will not work unless you have the cable from the media center to the monitor hooked up, I have all the parts from one of these due to the screen being defective on one of my customer's TV like yours. I have the connection cable that I could sell for $ 20. + Priority shipping of $5.65
10/11/2017 6:03:01 PM • JVC PD-42WV74 42... • Answered on Oct 11, 2017
JVC Plasma TV is half Tinted
If you wish to get some details; check the site linked here. Pull up older posts.... http://electro-medical.blogspot.com/
6/3/2016 4:04:37 PM • JVC PD-42WV74 42... • Answered on Jun 03, 2016
JVC Plasma TV is having Half tinted screen
The TCON board or the LCD panel is faulty. You have to replace the TCON board to confirm it. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
6/3/2016 4:04:26 PM • JVC PD-42WV74 42... • Answered on Jun 03, 2016
42 inch techwood plasma no picture
the most common cause for this is the capacitor (1uf 630vdc)located at c19 on the main power board.the cost for this component is around 90p
7/10/2014 5:48:37 PM • JVC PD-42WV74 42... • Answered on Jul 10, 2014
Intermittent black or snowy horizontal bar across the top
You're somewhat sound in electronics I assumes. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
5/18/2013 5:23:31 AM • JVC PD-42WV74 42... • Answered on May 18, 2013
2answers
Techwood 42 plasma
if you still need the fix for this repost i have just repaired mine i had a 1 inch thick line just off centre .this is a easy fix no parts required.
4/22/2013 8:49:40 AM • JVC PD-42WV74 42... • Answered on Apr 22, 2013
0answers
3answers
Need a display tuner jvc pd-42wv74
guess what? I have the EXACT same tuner that u're looking for... my place was broken into and they TOOK the tv monitor... but left behind the tuner . smart thief. if u're interested in buying this tuner to make ur tv complete again. (its in MINT condition) email me at [email protected] and put in JVC PD 42wv74 plasma tv in subject so i d know who it was. thanks.
7/7/2012 4:41:53 PM • JVC PD-42WV74 42... • Answered on Jul 07, 2012
Panasonic TH-50PX70EA HAS A HALF SCREEN PERFECT BUT OTHER HALF IS LINED AND CHANGES COLOUR AND SOMETIMES GOES BLACK GETS CLOSE TO PERFECT THEN GOES LINED AGAIN PS sorry for caps
If its a Plasma it uses sustain or t con boards--sustain will usually be two--one for left side and one for right.Only boards are sold for these sets--no individual parts--discover which board drives the right side and replace it while crossing your fingers--either it fixed the problem or you have a bad display panel (entire screen unit which is fatal from a cost point of view).
4/23/2012 4:15:32 PM • JVC PD-42WV74 42... • Answered on Apr 23, 2012
JVC PD-35D30ES Vertical lines - problem
HelloCheck its power supply board for any damaged capacitors. Replace them if found or suspected. Take special care to main filter capacitors. check all the output voltage smoothing capaciotrs too.If all are OK, and still the problem perists, replace the power supply board as card basis.
2/8/2012 1:51:20 PM • JVC PD-42WV74 42... • Answered on Feb 08, 2012
My Wifey sprayed windex on
DO NOT LET LIQUID DRIP BELOW BOTTOM OF SCREEN
Use warm water and a very small amount of washing liquid on a WELL WRUNG OUT cloth and wipe over screen area. You may need to do this several times and finish with warm water only. I repeat DO NOT LET LIQUID DRIP BELOW BOTTOM OF SCREEN
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
3/6/2011 7:39:13 PM • JVC PD-42WV74 42... • Answered on Mar 06, 2011
Green light blinking and TV will not turn on
In many sets, this is an indication of a failed power supply voltage. There are at least two supplies in every set; one is active always so the set can receive commands from the remote and requires minimal power and rarely fails. The other is turned on when the set is to be used and this one, is the likely culprit.
The type of supply used in modern sets is called a 'switched mode' power supply that operates at higher (than audible) frequencies in the range of 50,000 cycles and up. The supply first makes DC voltage from the AC input of 100-220 volts, then chops it at the elevated frequency. This design is much more efficient than the older type of 'linear' supply but is more complicated and critical in the quality of parts used.
These modern supplies are fussy about the quality of certain components and most will eventually fail due to crappy electrolytic capacitors, a part used for filtering and in feedback paths and they, by nature, don't really like these higher frequencies; they tend to break down chemically and lose their value until finally not performing as capacitors any more. This causes the supply to fail at starting up and more rarely, to cease operating while in service and sometimes develop internal losses that cause it to heat up and burst or at least bleed chemicals either of which causes their final death.
There are capacitors that are more resistant to this kind of decay but cost 2-5 times as much as common types and with the severe price competition in consumer electronics, manufacturers save where they can and use parts that will at least survive the warranty period.
I suggest you contact the service center for your area and inquire about the cost of board repair or replacement. If the latter, keep the failed board since there are small shops (I was one before retirement) with the skills to repair these at a more reasonable cost.
Before opening the back of your set, pull the plug and allow to sit, preferably overnight. There are nasty voltages inside that you want to avoid. The main power supply is often on a separate board, will have larger-than-average parts on it, with cylindrical parts (mostly capacitors) and some larger squarish parts (chokes and transformers) and most likely a 'heat sink,' a finned aluminum structure with parts attached to it. Look for a tag with a part number on it and have this available when you start looking for service or new board.
These assemblies are nearly always only plugged into the rest of the set with clearly dissimilar plugs so incorrect connections are somewhat prevented.
If you are unsure of yourself, take several pictures of this area before disconnecting anything that you can then refer to if uncertain. Remember, many assemblers of most of these just recently came in from small farming villages in Asia so assembly is kept simple. Good luck-
7/16/2010 3:17:48 PM • JVC PD-42WV74 42... • Answered on Jul 16, 2010
How do i solve the image burn i keep having
Get a DVD with very bright, fast action content and have it play over and over when you aren't watching the television. Play it until the burn in image is removed. BRIGHT!!! Not a dark movie.
6/12/2010 6:42:17 PM • JVC PD-42WV74 42... • Answered on Jun 12, 2010
JVC PD-42WV74 42 in. Plasma EDTV Logo
51 questions posted
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
panasonic th 50px70ea half screen
  • Televison & Video
