20 Most Recent
Casio Baby-G BG169-2V Wrist Watch Questions & Answers
Need the instruction manual for my Baby-G
Hi,you can download a soft version of the user manual on below link. .when you open the link just write the 4 digits code on the back side and click searched on the URL below
Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks***************************CASIO Watch User Manual Archives http://world.casio.com/wat/download/en/manual/Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
How do i set the time, day, and date on the baby g
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search bo
I want to know how to set an alarm on my baby g
watches;
Accept terms
Read the number of the back of your watch and enter it into the search box
I have a digital watch and i cant change the time
If you haven't got instructions on how to do this, you can get them from the Casio web site.
watches;
Accept terms
I can't find out how to set the time, date, etc.
instructions
Select
watches;
Accept terms
Select
How to set time
May I get the make and model # of the wtch to help you more
HOW TO SET THE TIME ON CASIO BABY G WATCH
I assume that you haven't got the instructions. If you wish to obtain them then:-Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Click on "search" and the download your instructions.
How to adjust time
good morning ! to set your baby g casio watch , press the adjust button to make digit blinking when the digit blinking you can chagne the digit press the mode button,and next use the two to chagne digit after seting press the adjust button and the time is gona be normal,thanks po !..
When I press light buttopn in the middle the display goes blank
This sounds like a simple battery replacement. Depending on how low the battery is usually pressing the light button and the display goes dim or blank is a good indicator of this. Takes a CR1616 battery and be careful of the spring inside and make sure the seal is in the correct position. You will need to touch the AC button and the back of the battery with a pair tweezers for a couple of seconds to reset the watch. Put the case back on and set the watch thru the functions.
Casio Baby-G BG-460
You do not have to take the watch apart to replace the band. You will need a spring bar tool to do this.
