20 Most Recent Casio Marine Gear AMW320D9EV Wrist Watch Questions & Answers
Check watch caceback. All numers are there. Upload the numbers here and then we can help.
Use an eyeglass if numbers are too small.
Casio Marine... | Answered on Aug 20, 2013
This sort of problem is usually caused by the fact that the watch is 12 hours out and can be solved by advancing the time 12 hours (the watch thinks it is midnight when it is actually mid-day) but the fact that yours changes at 5 p.m. and not 12p.m. is unusual.
Unless you are a night shift worker you could just wind it on 12 hours and accept it changes at 5a.m. Otherwise, speak to the maker with a view to getting a replacement under warranty, as it would seem that the watch has not been correctly assembled.
Casio Marine... | Answered on Feb 10, 2011
For all those who lost their Casio watch manual. Follow this link, fill in the requested details and download manual. http://world.casio.com/wat/download/en/manual/
Casio Marine... | Answered on Nov 15, 2010
browse through my tips and you will find link for all Casio watch manual downloads.
Casio Marine... | Answered on Oct 01, 2010
Hi, If you don't have the manual, Try this link:
Take the four-digit module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Casio Marine... | Answered on Sep 08, 2010
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Casio Marine... | Answered on Jun 22, 2010
This part is called the bezel, you are correct. They are available to buy as a separate item for certain watches, but not all. You didn't mention what type of watch it was. Most major brands, like Rolex, Omega, Tag Heuer etc all sell bezels for their watches, brands though like Diesel, Rotory, Seiko etc, do not sell bezels as a stand alone item. Should you wish to let me know the make and model of the watch, I will see if I can obtain one, or failing that I will see if I have one that will fit.
Casio Marine... | Answered on Apr 26, 2010
sounds like repairer for got to AC watch they may have forgot to do this simple task...some times they also have 2 batterys one under the other.did you do it yourself re blog if you did and i will go through sequence
Casio Marine... | Answered on Mar 26, 2010
Speak to your local Casio dealer, it could be that the battery needs replacing, (some watches can need replacements if they have power hungry features which have been used frequently.
If this is not the case, then if there is anything wrong with the watch, then it should be repaired under warranty.
Casio Marine... | Answered on Mar 01, 2010
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps.
R/
David
Casio Marine... | Answered on Feb 09, 2010
To reset the battery you need to locate the "AC" inside your watch. The AC terminal is a little metal spot (usually a circle and usually gold colored) on the inside of your watch. Looking at the inside of your watch the "AC" should be labeled, though it may take a magnifier to identify it.
It may be labeled simply "AC" or it may have an arrow pointing to it. Once you locate it use a pair of tweezer or a paper clip and touch the battery and the AC together for a few seconds and release; you may have to do this twice. This will reset your watch an give you the ability to correctly wet your watch.
Casio Marine... | Answered on Oct 21, 2009
To sync the correct 12 hour with your day you need to set the date to the day before (if today is 21, then make sure the day window reads 20). Then spin the analog hands until the the date window turns to 21. At this point your watch is reading 12 AM (midnight). Then keep turning to set the correct time. If it is 9 am then stop the hands the first time you hit the 9 marker. If it is 9pm, then keep turning until the SECOND TIME your hour hand meets the 9 marker. This is now set for 9 pm.
That's how you do it. If you need more clarification let me know.
I clipped a driver pin out of a safety pin and tapped the band pins out with the driver pin and a hammer. It helps to have someone hold the band on a hard place over a hole.
geb
Casio Marine... | Answered on Dec 28, 2007
Casio Marine Gear AMW320D9EV Wrist Watch Logo
19 questions posted
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Gear Casio
  • Gear Casio
Most Popular Question
dont problem
  • Watches
