20 Most Recent Casio Forester PAS400B-5V Wrist Watch Questions & Answers
2answers
Why does my Casio 2628 watch keep resetting itself
The solution is that I will take it back to the place I bought it, because the watch is nearly new.
6/14/2016 1:11:36 PM • Casio Forester... • Answered on Jun 14, 2016
Changed battery .A square piece of metal the size
mcdevito75 here, Of couse without the watch and piece of metal that fell out it"s very hard to say. Most likely it was part of the lock-down tab to keep the battery in place, in any event don"t lose that piece of metal. If your casio is working ok don"t worry about it, just don"t lose that piece of metal that fell out.
5/8/2014 7:46:25 PM • Casio Forester... • Answered on May 08, 2014
HOW TO SET TIME
Hi eddiepaul,
This watch is fairly complex, with all the many features and modes. I could list this procedure out here, taking up an entire page, but I will say you start by pressing button "D" on the lower left, one time. Setting the time is the first of 6 (Six) modes of operation. Your watch module number is probably a #2632, and module #2805 is basically the same.
If you don't have the manual, go here and download, save and printout the manual for complete instructions for everything about this watch.
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2632.pdf
You'll find what you need for setting the date and time on page 1.
It's hard to believe Casio packed so many features in such a reasonably price watch! I've had Casio and Timex with all these modes, and love 'em!
Let me know if I can be of further assistance.
Regards, Bill
9/16/2010 6:29:59 PM • Casio Forester... • Answered on Sep 16, 2010
Casio Fisherman (PAS400B) watch replacement clip for spring pins
mcdevito75 here, I'm surprised a jeweler couldn"t help. Here is Casio"s contact number, speak with them, TIP, get a spring bar 1/2 MM smaller and larger than what you measured. Contact Casio at 800-435-7732 9AM-----5 PM EST. hope this helps.
8/3/2010 6:35:57 PM • Casio Forester... • Answered on Aug 03, 2010
What is the main internal
mcdevito75 here, The Internal workings of all watches and clocks, Quartz and mechanical is called the movement. You may have a weak or even dead battery, even if the battery is new. If you"ve dropped your watch, got it water logged, you could have hurt the Quartz movement. It'll take special equiptment to check the Quartz movement to see if it"s burned out. I would try another battery or at least double check this batteries instalation in your watch. For more info, here is Casio"s contact number, 800-435-7732 9AM--5PM EST.
8/3/2010 4:58:11 PM • Casio Forester... • Answered on Aug 03, 2010
How do i set the time change on my daughters casio
http://world.casio.com/wat/download/en/manual/
There are so many aplications use of the manual will be manditory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
3/14/2010 2:10:59 AM • Casio Forester... • Answered on Mar 14, 2010
The manual is too small to read. I just want to
Put your manual in to your scanner and scan it. Save in to your PC and then read it by using ZOOM tool.
2/28/2010 2:43:40 PM • Casio Forester... • Answered on Feb 28, 2010
My Casio digital watch changes the date at 12 noon rather than at midnight. The model is 5479. How can I solve this issue?
Time is not set correctly. You set the time as AM instead of PM and vice versa. Use the following manual to set time correctly. QW-5479 (casio.com)
12/31/2023 10:43:33 AM • Casio Watches • Answered on Dec 31, 2023
Why does everything equal zero when hitting EXE on
You may find a solution here:
If it does not work, use casioworld button on same page as it may help.
Rate me, please.
12/20/2023 1:53:16 PM • Casio Watches • Answered on Dec 20, 2023
Casio Analog MTP-1216 Watch. How do I get the pressure back off the 1216 Casio please?
Question edited for clarity. Question moved to Casio Watch, from Office Equipment. Pressure backs need a tool to unscrew the back and the gasket should be checked and greased. Best advice here https://www.fixya.com/support/r27181038-changing_watch_batteries ..
11/11/2023 11:54:03 PM • Casio Watches • Answered on Nov 11, 2023
My Casio Sea Pathfinder SPS-300 2572 functions perfectly except for no sound. I know when I set an alarm it does trigger because I can see the Alarm Icon flashing. Why is there no sound? Thank you
It is likely that the battery is depleted sufficiently that the sound feature can't work. Take it to a local jeweler for battery replacement service. https://www.fixya.com/support/r27181038-changing_watch_batteries ..
10/20/2023 3:16:08 AM • Casio Watches • Answered on Oct 20, 2023
Re Casio Waveceptor watch
limited info generic answer if its the lower $ end units-- pop off the back --and remove internals careful of springs for buttons --check for debris -failed spring-button bi-metal fail /damaged
8/23/2023 6:38:11 PM • Casio Watches • Answered on Aug 23, 2023
2answers
How to fix Quartz on my casio 708 mtp 3036
This is a job a specialist watch repairer should do. It will need specialist tools so if you are not familiar with working on watches pay someone to do it for you. Also consider the cost of repair. It might be cheaper to simply buy a new watch.
5/17/2023 6:49:58 AM • Casio Watches • Answered on May 17, 2023
Hoe kan ik een handleiding vragen van Casio. No.3464. Heb een Casio horloge gekocht maar is geen Nederlandse handleiding bij?
Question edited for clarity and spelling 'casino' to 'Casio'.Question Translated to English. We are a North American website.Question moved to Casio Watch category.https://www.google.com/search?q=casio+watch+netherlands..
4/23/2023 4:33:23 PM • Casio Watches • Answered on Apr 23, 2023
Casio Forester PAS400B-5V Wrist Watch Logo
15 questions posted
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Forester Casio
  • Forester Casio
Most Popular Question
casio fisherman pas400b watch
  • Watches
