20 Most Recent Casio SL-100 Calculator Questions & Answers
0answers
SL-100L
Be the first to answer 9/3/2012 4:10:52 AM • Casio SL-100... • Posted on Sep 03, 2012Be the first to answer
As the VAT has changed in the UK to 15% instead of
Hi. Switch on using the Ac button
Press the TaxSet button - and hold for 2/3 seconds
You will be show either the current tax held or zero
Type in the tax you want ie 15
Now press the taxSet button.
To verify its worked prees Ac button then press the Tax+ button is should now show you 15%. Hope this helps.
4/30/2009 9:32:47 AM • Casio SL-100... • Answered on Apr 30, 2009
How to Convert a 4-digit decimal no. to the binary format in Casio fx-991MS
The way to do it is this; Divide the number by 2, get the integer quotient for the next iteration. Get the remainder for the binary digit, repeat the steps until the quotient is equal to 0.
3/22/2024 7:20:35 AM • Casio Office... • Answered on Mar 22, 2024
My casio F-28W is showing (complete display ). What is its solution
It is because it is not set up correctly. For you to fix it, just press on the lower right button for few seconds till it displays " cas10" then let go of the button
3/11/2024 12:58:15 PM • Casio Office... • Answered on Mar 11, 2024
Casio Add Mach DR-120R - not printing correct numbers. 0 for 1, 1 for 2, etc. Recently had to remove ribbon from gears. Tried re-setting it, but it did no good.
Here is the Service Manual, but in normal instances, you would just buy another one, or return it to Casio for service.
Casio DR-120LB Service Manual
ManualsLib https://www.manualslib.com > ... > DR-120LB View and Download Casio DR-120LB service manual online. DR-120LB cash register pdf manual download. Also for: Dr-200l, Dr-210l, Dr-320b, Zx-517c, Zx-517a, ... ..
2/28/2024 6:17:34 AM • Casio Office... • Answered on Feb 28, 2024
My screen says [Dec] and I cant do normal calulations with it there. I have a casio fx-991EX calcultor
If your Casio fx-991EX calculator is displaying [Dec], it means it's in Decimal mode. To switch back to normal calculations, press the MODE button and select the desired mode, such as COMP for computation or MATH for mathematical functions. I think this will solve your problem
1/5/2024 2:27:36 PM • Casio Office... • Answered on Jan 05, 2024
2answers
How Can POS software increase Profit?
Retail pos software one of best thing to maintain your store inventory properly. Because if anyone inventory incorrect by mistake then you can lose bing amount.
1/4/2024 6:12:10 AM • Casio Office... • Answered on Jan 04, 2024
How do i do prime numbers on the NEWYES NY-991MS calculator and CTIFREE fx-991ES PLUS calculator?
The NEWYES NY-991MS and CTIFREE fx-991ES PLUS calculators do not have a dedicated "FACT" button like the Casio FX-83GTX. However, you can still find prime numbers on these calculators.To find prime numbers:NEWYES NY-991MS:Press the "MODE" button.Choose "PRIME" from the list of options.Enter the desired number and press "=" to check if it's prime.CTIFREE fx-991ES PLUS:Press the "MODE" button.Select "TABLE" or "TABLESET."Input a starting point and an ending point, then observe the table for prime numbers.Although the techniques may vary from those used on the Casio FX-83GTX, they prove to be effective for prime number calculations on the designated calculators.
1/2/2024 8:14:22 AM • Casio Office... • Answered on Jan 02, 2024
How do I reset the HR-100TM Casio printer back to original setting
There is a reset button on the back of the Casio. If that does not work, you may find an alternative method in the manual. CASIO HR-100TM USER MANUAL Pdf Download ' ManualsLib
11/2/2023 5:31:01 AM • Casio Office... • Answered on Nov 02, 2023
Casio FX-570MS 2nd edition calculator. Solve s28 to show answer in terms of 2sqrt7 not decimal.
Question edited for clarity and toss in some CAPS. Maths is important, but ritten English is more importanter :>D No idea what any of that means :>/ But this appears to be the answer. Our Maths Expert just retired from Fixya. https://www.google.com/search?q=Solve+s28+to+show+answer+in+terms+of+2+sqrt+7+not+decimal ..
10/10/2023 6:33:58 PM • Casio Office... • Answered on Oct 10, 2023
Can I omit printing the time on the Casio HR-170RC?
On Page 2 apparently not. It is a very basic machine. You can turn printing off altogether. https://support.casio.com/storage/en/manual/pdf/EN/004/HR-170RC_200RC_WA_EN.pdf ..
9/27/2023 5:07:33 AM • Casio Office... • Answered on Sep 27, 2023
CASIO Fx-260 Solar Sine Cosine Problems
Refer to user manual at this link fx-82SOLAR_260SOLAR II_260SOLAR II NF (casio.com) It will tell you the limitations.
9/14/2023 2:11:16 PM • Casio Office... • Answered on Sep 14, 2023
Casio QT-6600 kitchen printer stop working.
Is there lights on, on the printer? Does it have a receipt paper roll in it? You can do a Power Cycle of the Terminal and the Printer. Unplug the printer for the wall socket. Remove the data socket, replace the data socket making sure the connection is tight. Disconnect the terminal from the main power, and count to 20. Plug the terminal back in. Now go to the kitchen and plug the printer back into the mains. The reset should fix it. The rest is in the manual, which I told you earlier today. Yes it is complicated and you may have a network switch if you have multiple terminals and possibly a computer joining everything. If you find that too complicated, call the company that sold you the unit and tell them to bring a new ticket printer with them 'just in case'. That type if ticket printer is fairly specialized, but they are common. They normally don't charge for that type of help In the manual under Remote Printer Control. https://totalpos.co.nz/wp-content/uploads/2020/03/QT6600-Reference-Manual.pdf More here https://www.google.com/search?q=Casio+QT-6600+connect+kitchen+printer ..
9/4/2023 6:05:56 PM • Casio Office... • Answered on Sep 04, 2023
How to calculate percentage with Casio fx-991EX?
To find the percentage of a number: Let's say you want to find 20% of 150.
  • Enter the number you want to find the percentage of (150 in this example).
  • Press the multiplication key (*).
  • Enter the percentage value (20 in this example).
  • Press the percentage key (%).
The calculator will display the result, which in this case is 30 (20% of 150 is 30
8/6/2023 6:03:17 AM • Casio Office... • Answered on Aug 06, 2023
Is it possible to have a result of a calc expression without inserting x value? Casio fx991ex
Yes, the Casio fx-991EX scientific calculator has a feature called "natural display" which allows you to input and display mathematical expressions exactly as they appear in textbooks, including variables such as "x".
To perform the calculation you mentioned, 2x * 2 = 4x, simply enter the expression "2x*2" into the calculator, and it will display "4x" as the result. You can then use this result in further calculations without having to enter a value for "x".
To enter the variable "x", you can use the "ALPHA" key followed by the corresponding letter key. For example, to enter "x", press "ALPHA" followed by "X".
Note that if you want to solve for a specific value of "x", you will need to use the solver or equation mode on your calculator to input the equation and specify the value of "x" you want to solve for.
3/14/2023 5:57:01 PM • Casio Office... • Answered on Mar 14, 2023
When I try to divide two numbers with no divisors in common, the calculator goes off
t's possible that you are encountering a problem known as "divide by zero," which occurs when you try to divide a number by zero. Most calculators, including the CASIO fx-570ES PLUS, are not designed to handle this type of calculation and will usually display an error message or simply "go off." This is because dividing by zero is not a well-defined mathematical operation and does not have a meaningful answer.
2/14/2023 6:07:39 PM • Casio Office... • Answered on Feb 14, 2023
Casio SL-100 Calculator Logo
Popular Tags
8 questions posted
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Casio Office Equipment & Supplies
Most Popular Question
as vat changed in uk 15 instead
  • Office Equipment & Supplies
