20 Most Recent Casio JF-100TE Calculator Questions & Answers
How to disable auto power off
You can't. When you think it is going to shut itself off, press some key.
5/22/2018 12:59:15 AM • Casio JF-100TE... • Answered on May 22, 2018
CHANGE TAX %+ & TAX- ON MY CASIO JF-100TE CALCULATOR
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
1/13/2014 7:20:35 AM • Casio JF-100TE... • Answered on Jan 13, 2014
Casio JF-100TE Battery Replacement
Taking the back off The Casio JF-100 calculator is similar to the ...TE. Remove the two screws at the top back. Place a small screwdriver blade along the seam where the back plate fits into the front plate. There are 3 fasteners on each long side and 1 fastener on each of the front and back sides. Find the spot where it's the easiest to separate the back plate from the top plate (there are only two). Carefully twist the blade to cause an opening. Then proceed sequentially around the perimeter releasing each fastener. The front plate will easily separate from the back plate at this time. There are no parts that will fall-out--don't worry. Replace the battery. Press the front and back plates together to snap the fasteners.
11/23/2013 5:00:38 PM • Casio JF-100TE... • Answered on Nov 23, 2013
Tax Rate
step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 6 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 6 should be displayed
11/20/2012 5:52:12 PM • Casio JF-100TE... • Answered on Nov 20, 2012
How do i set the euro conversion rate on my casio
Already answered here: http://www.fixya.com/support/t292440-casio_jf_120er_euro_rate_set
4/3/2010 7:20:13 AM • Casio JF-100TE... • Answered on Apr 03, 2010
How do you turn off this calculator.
It is solar powred and will turn off by itself. Don't worry it doesn't cost anything.
9/10/2008 2:19:17 PM • Casio JF-100TE... • Answered on Sep 10, 2008
How to Convert a 4-digit decimal no. to the binary format in Casio fx-991MS
The way to do it is this; Divide the number by 2, get the integer quotient for the next iteration. Get the remainder for the binary digit, repeat the steps until the quotient is equal to 0.
3/22/2024 7:20:35 AM • Casio Office... • Answered on Mar 22, 2024
My casio F-28W is showing (complete display ). What is its solution
It is because it is not set up correctly. For you to fix it, just press on the lower right button for few seconds till it displays " cas10" then let go of the button
3/11/2024 12:58:15 PM • Casio Office... • Answered on Mar 11, 2024
Casio Add Mach DR-120R - not printing correct numbers. 0 for 1, 1 for 2, etc. Recently had to remove ribbon from gears. Tried re-setting it, but it did no good.
Here is the Service Manual, but in normal instances, you would just buy another one, or return it to Casio for service.
Casio DR-120LB Service Manual
ManualsLib https://www.manualslib.com > ... > DR-120LB View and Download Casio DR-120LB service manual online. DR-120LB cash register pdf manual download. Also for: Dr-200l, Dr-210l, Dr-320b, Zx-517c, Zx-517a, ... ..
2/28/2024 6:17:34 AM • Casio Office... • Answered on Feb 28, 2024
My screen says [Dec] and I cant do normal calulations with it there. I have a casio fx-991EX calcultor
If your Casio fx-991EX calculator is displaying [Dec], it means it's in Decimal mode. To switch back to normal calculations, press the MODE button and select the desired mode, such as COMP for computation or MATH for mathematical functions. I think this will solve your problem
1/5/2024 2:27:36 PM • Casio Office... • Answered on Jan 05, 2024
2answers
How Can POS software increase Profit?
Retail pos software one of best thing to maintain your store inventory properly. Because if anyone inventory incorrect by mistake then you can lose bing amount.
1/4/2024 6:12:10 AM • Casio Office... • Answered on Jan 04, 2024
How do i do prime numbers on the NEWYES NY-991MS calculator and CTIFREE fx-991ES PLUS calculator?
The NEWYES NY-991MS and CTIFREE fx-991ES PLUS calculators do not have a dedicated "FACT" button like the Casio FX-83GTX. However, you can still find prime numbers on these calculators.To find prime numbers:NEWYES NY-991MS:Press the "MODE" button.Choose "PRIME" from the list of options.Enter the desired number and press "=" to check if it's prime.CTIFREE fx-991ES PLUS:Press the "MODE" button.Select "TABLE" or "TABLESET."Input a starting point and an ending point, then observe the table for prime numbers.Although the techniques may vary from those used on the Casio FX-83GTX, they prove to be effective for prime number calculations on the designated calculators.
1/2/2024 8:14:22 AM • Casio Office... • Answered on Jan 02, 2024
How do I reset the HR-100TM Casio printer back to original setting
There is a reset button on the back of the Casio. If that does not work, you may find an alternative method in the manual. CASIO HR-100TM USER MANUAL Pdf Download ' ManualsLib
11/2/2023 5:31:01 AM • Casio Office... • Answered on Nov 02, 2023
Casio FX-570MS 2nd edition calculator. Solve s28 to show answer in terms of 2sqrt7 not decimal.
Question edited for clarity and toss in some CAPS. Maths is important, but ritten English is more importanter :>D No idea what any of that means :>/ But this appears to be the answer. Our Maths Expert just retired from Fixya. https://www.google.com/search?q=Solve+s28+to+show+answer+in+terms+of+2+sqrt+7+not+decimal ..
10/10/2023 6:33:58 PM • Casio Office... • Answered on Oct 10, 2023
Casio JF-100TE Calculator Logo
17 questions posted
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Casio Office Equipment & Supplies
Most Popular Question
casio jf 100te battery replacement
  • Office Equipment & Supplies
