20 Most Recent
Edu-Science Edu Science Deluxe Microscope/Telescope Questions & Answers
Do & Discover Crystal Growing
I patiently used Google Translate and got this. The instructions may not be in perfect English, but it's good enough to understand. Good luck :)GROWING CRYSTALS
1. experiments require a large measurement cup (at least 32fl oz / 0.9 1) Heat resistant glass mix the powder and boiling water. The vessel measures must be glass or plastic Resistant to heat. You also need a medium saucepan (at least 32 fl oz / 0, 9 1) to boil water. Separate carefully cut molds, as pictured. Make sure to leave a border around each mold. Also remove sharp edges from the edges with scissors.
2. Use a large glass measure (at least 32 fl oz / 0, 9 1) (not included) to measure 0.68 liters of water and pour into a medium-size saucepan. Heat the pan until the water boils.
3. Open the bag of potassium sulfate 10 (diamond frosting) with chemical crystal growth and pour the contents into the glass of measures.
4. Pour boiling water in medium saucepan shot glass with the contents of the bag 10.
5. Stir the mixture with the big stick until all the grains are completely dissolved chemicals. NOTE: Let the mixture cool for 5 minutes after the grains have dissolved.
6. placed 2 rocks on the bottom base of the 5-sized plastic molds "C" of growth. These basement rocks should rise only about 3 / 4 "(2cm) from the bottom of mold growth.
7. Pour the chemical solution / water shot glass molds in size 5 "C" for crystal growth. Make sure to fill each mold in the same way, leave an inch (8mm) of space between the liquid and the edge.
8. After removing the bottle cap coloring dye, carefully cut with scissors (not included) the tip of the boat. Individual drops slowly drops of dye into the mold of crystal growth. see diagram following Mercedes to mix colors. Once you add the dye mixture solution with the small mixing stick. NOTE: Do not add dye to the mold of a glass. transparent crystals are better for the electronic.
9. Place the mold of crystal growth in a place where not disturbed by movements or changes in temperature. crystals begin to grow in a matter of hours. let the crystals grow for three or four days without disturbing them. You can then remove the crystals from the solution. For best results, wash the crystals abundantly in the sink to remove excess dye and place on a newspaper or paper towel for a day to dry.
10. if the mass of rock crystal and the base have been a square shape due to the structure of the mold growth, you can break the remaining crystals that form the block so that the crystalline mass display look more natural from the geological point of view. to expose the glass, LED lights the base by pressing the button on the bottom. transparent glass placed at the base and see how it changes color. if you are not using the base, be sure to extinguish by pressing the button again. to replace the battery, remove the cover with a screwdriver as shown below. NOTE: with the help of a magnifying glass, look closely at the detailed crystal structure of the crystals finalized.
Beak-shaped crystals: follow steps 2-10 with the following changes: In step 2, only 0.34 a boil water. In step 3, use the contents of the bag 11.
In step 6 uses the five molds size "D" of growth of crystals with a single rock in each base.
In step 8 uses color guidelines mold "D" (crystals spike) in the diagram below.
NOTES: replacement of the battery base. Place the base upside down. Now you can remove the battery cover to access it, as shown in the image below.
I have three foster sons
Welcome to Fixya. i I've seen the website of Edu-Science however they dont have the link to download a manual for the Magnet Deluxe. I've provided the link of the product and the contact info of Edu-Science aswell you can send them an email and ask if they have the copy of the manual.
Edu-Science Magnet Deluxe
Edu-Science Contact Info
If you have questions please let me know. Thanks for using Fixya
We have a rock tumbler
Fill the barrel most of the way with stones, add coarse grit, add enough water to just cover the stones and then clean where the lid seals carefully. Seal it up and run it for a week, dump everything into a colander and rinse. Don't run that mud down your drain because it will plug it mightily, run it outside.
Do the same process with the fine grit, run it for another week and rinse and admire.
lp
Hi I've got a babyweaver
Sounds like you are missing the central support rod or bar that connects the Babyweaver swinging crib to the stand, providing stability and support for the crib. This component is crucial for maintaining the structural integrity of the crib and ensuring safe usage. Here are some steps you can take to address the missing part:
1. Contact the Manufacturer:
- Reach out to Babyweaver or the manufacturer of the swinging crib to inquire about obtaining a replacement central support rod.
- Provide them with details about the missing part and the specific model of the swinging crib to ensure you receive the correct component.
2. Check for Spare Parts:
- Check if the swinging crib came with a user manual or assembly instructions that may have information about spare parts or replacement components.
- Look for any contact information provided for customer support or spare parts inquiries.
3. Online Search:
- Conduct an online search using keywords such as "Babyweaver swinging crib central support rod" or "Babyweaver crib replacement parts" to see if you can find the specific part for purchase.
- Explore baby product retailers, online marketplaces, and specialty stores that offer replacement parts for nursery furniture.
4. Local Retailers:
- Visit local baby product stores or furniture stores that carry nursery items.
- Bring the existing part (if you have one side of the support rod) to help them identify and match the missing component.
5. Custom Fabrication:
- If you are unable to find a suitable replacement part, consider contacting a metal fabrication shop or a carpenter who may be able to custom-make a central support rod that fits your Babyweaver swinging crib.
- Provide them with measurements and details about the required specifications for the part.
3/22/2024 3:29:32 AM •
Toys
Answered
on Mar 22, 2024
I have a new model teddy ruxpin and my 2 year old daughter tripped and dropped him. His lights all come on but his app and sound are not working
It sounds like the drop may have caused some internal damage to the electronics or wiring of the Teddy Ruxpin toy. Here are some steps you can take to try and troubleshoot the issue:
- Restart the Toy: Sometimes a simple restart can resolve minor issues. Try turning off the toy completely, including any power switches or buttons, and then turning it back on again after a few moments.
- Check Battery Compartment: Ensure that the batteries are properly inserted and making good contact with the terminals inside the battery compartment. If the drop caused any displacement of the batteries, it might affect the toy's functionality.
- Inspect for Physical Damage: Carefully examine the exterior of the toy for any signs of physical damage, such as cracks, dents, or loose parts. If there's visible damage, it may indicate internal damage as well.
- Test with Different Devices: If the Teddy Ruxpin toy connects to a separate app or device for sound playback, try connecting it to a different device to see if the issue persists. This can help determine if the problem lies with the toy or the connected device.
- Contact Customer Support: If none of the above steps resolve the issue, it's possible that the drop caused internal damage to the toy's electronics or wiring. In this case, you may need to contact the manufacturer's customer support for assistance. They may be able to provide further troubleshooting steps or offer a repair or replacement option.
Keep in mind that since the toy is relatively new, it may still be under warranty, which could cover repairs or replacements for damage caused by accidents like drops. Be sure to check the warranty information or contact the manufacturer for guidance on warranty coverage.
3/21/2024 2:25:15 PM •
Toys
Answered
on Mar 21, 2024
Fisher-Price J7485 T-Rex stopped moving
Check Batteries: Ensure that the batteries are properly inserted and have sufficient charge. Sometimes, a low battery can cause the toy to stop functioning.
Switch On/Off: Confirm that the toy is switched on. Some toys have an on/off switch or button that might accidentally get turned off.
Connections and Wires: Inspect the wires and connections inside the toy. Loose wires or faulty connections can lead to malfunction.
Obstructions: Look for any obstructions or debris that might be preventing the T-Rex's movement. Clear any blockages.
Reset: If there's a reset button, try pressing it. This can sometimes resolve minor issues.
Contact Customer Support: If none of the above steps work, consider reaching out to Fisher-Price customer support as below.
https://service.mattel.com/us/ContactUs.aspx
2/22/2024 2:51:59 PM •
Toys
Answered
on Feb 22, 2024
