20 Most Recent Vizio E601I-A3 60-inch Class Razor LED HDTV - Smart TV - 1920 x 1080 - Questions & Answers
Model e601i-a3 TV. On the left side it's dim (flickers) and on the right side it's very dim or dark. What's wrong?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts or search the site by type in the brand name of your set, at its search box at the right column.. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/
5/19/2021 12:37:06 PM • Vizio E601I-A3... • Answered on May 19, 2021
0answers
Visio Model E601I-A3 TV shuts off randomly. Is it a bad power supply board?
Does appear to be a PS issue.
12/28/2016 6:18:28 AM • Vizio E601I-A3... • Answered on Dec 28, 2016
Screen is black but I can hear sound.
Most likely the power supply board needs to be replaced. It could also be the backlighting. A few TV's have a separate power board just for backlighting, but not many. If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED! If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
9/21/2016 4:50:10 AM • Vizio E601I-A3... • Answered on Sep 21, 2016
Vizio intermittent backlight
You have to check the power supply of the tv. Normally led TVs power suppy is integrated with the led driver. If the led driver is faulty then this type of problems can occur. If you wish to get some more details then check the following link. http://electro-medical.blogspot.com/
7/21/2016 4:26:03 PM • Vizio E601I-A3... • Answered on Jul 21, 2016
Fix a vizio tv e601i-a3.has sound no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
6/1/2016 6:47:34 AM • Vizio E601I-A3... • Answered on Jun 01, 2016
What needs replaced? TV turns on then displays Vizio logo then shuts off and repeats over and over. Is this the T-con board or the power supply/led board?
Sounds like firmware corrupted. A firmware [software] update might be necessary. First, do a hard reset to this set, and check. If it do not help you, update the firmware. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
5/19/2016 11:00:51 AM • Vizio E601I-A3... • Answered on May 19, 2016
No signal from hdmi inputs
If none of the HDMI ports work, then the main board is the problem. You can get a new one here :
4/27/2016 8:06:24 AM • Vizio E601I-A3... • Answered on Apr 27, 2016
Why won't it turn off using the remote or controls on the TV itself?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
1/19/2016 11:05:54 AM • Vizio E601I-A3... • Answered on Jan 19, 2016
What is the problem with the screen going blank? the backlight still works I also believe the sound works as well. I am leaning towards the main board? does anyone have wiring diagrams or schematics
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Circuit diagrams of many popular brand TVs are given.
11/6/2015 3:10:56 AM • Vizio E601I-A3... • Answered on Nov 06, 2015
Vizio 601a3 power wont work
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
8/18/2015 10:48:48 AM • Vizio E601I-A3... • Answered on Aug 18, 2015
2answers
Hello, my VIZIO tv smart 60 has sound but no picture. It was during a storm and i was watching it and then booom it went out
Open back an replace the video board, or converter board. Get em from Jimmys tv repair.
6/22/2015 6:43:12 PM • Vizio E601I-A3... • Answered on Jun 22, 2015
What parts do I need to fix in my Vizio e601i-a3 tv?
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
6/22/2015 4:30:54 PM • Vizio E601I-A3... • Answered on Jun 22, 2015
Can I just plug in a USB Flash drive and record from TV Output...???
It depends on the model of TV? Most often times the USB port is an input.
4/1/2015 3:24:13 PM • Vizio E601I-A3... • Answered on Apr 01, 2015
Vizio E601I-A3 60-inch Class Razor LED HDTV - Smart TV - 1920 x 1080 - Logo
Popular Tags
37 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
just plug in usb flash drive record from
  • Televison & Video
