20 Most Recent
Naztech N30 Portable Boom White Statio Questions & Answers
What are the benefits of a wakeboard tower?
A wakeboard tower allows your boat to have more hang
time, it can be used for extra space to put wakeboard equipment (ie. racks,
speakers), and it can be served for support when walking around the boat.
10/18/2018 7:20:11 AM •
Water Sport
Answered
on Oct 18, 2018
I’m trying to buy a new bathing suit. According to the size chart my bust and hips are one size and my waist is another. Do I go with the bust and hip size? Thank you
Lots of ladies share your problem which is not easily overcome, especially if your waist is larger rather than smaller...
You really need to try on several costumes to find the best fit and in the lower price ranges you are likely to discover considerable variation between garments of the same theoretical size.
This is because the fabric tends to be cut to a tolerance rather than an exact size.
If your waist is smaller I suggest you choose a garment that provides the best fit for your hips and bust but if your waist is larger, practically speaking, you will have little choice and will need to buy to suit your waist and either compromise on the bust/hip fit or have a seamstress make a few slight alterations.
4/6/2018 3:11:15 AM •
Water Sport
Answered
on Apr 06, 2018
Do I need to wax the top of the paddleboard?
Most paddle boards are made with traction pads attached
to the top of the board, these should never be waxed. Boards that do not have
the traction pads should be lightly covered with a base wax.
2/5/2018 3:30:29 PM •
Water Sport
Answered
on Feb 05, 2018
99 yamaha xl 1200 limited rev problem no speed
if the wear ring is installed wrong or the impeller is full of debris this will be the result. look close at the wear ring for scrape marks from the propeller OR are you missing carpet off the rungs of the trailer ?
7/14/2017 1:53:23 AM •
Water Sport
Answered
on Jul 14, 2017
Yamaha waverunner won't idle and losing power
L stands for limp mode
it is a mode that the ECM selects to prevent serious damage to the engine ( from you lack of oil )
have the fault codes read then reset with the scan tool
3/31/2017 6:33:28 AM •
Water Sport
Answered
on Mar 31, 2017
Vw battery light on
Alt. Is bad pull battery's terminal off while car is running if it dies the alt.needs replaced
1/11/2016 7:16:25 PM •
Water Sport
Answered
on Jan 11, 2016
