20 Most Recent JVC HD-52G786 52" Rear Projection HDTV Questions & Answers
0answers
Tv doesnt turn on anymore power button flashs
Replace lamp.
9/29/2014 6:54:56 PM • JVC HD-52G786... • Answered on Sep 29, 2014
JVC TV no signal
IF YOU ARE REFERING TO IT SAYING WEEK SIGNAL IT IS BECAUSE YOU SHOULD BE ON HDMI INPUT FOR TV,go to menu scroll to hdmi -1or2 input for cable hdmi input,i had same thing.
8/23/2014 6:29:58 PM • JVC HD-52G786... • Answered on Aug 23, 2014
Why when playing from phone the tv cuts off
NOT SURE WHAT YOU MEAN TV AND PHONE CONNECTED,UNLESS YOU ARE TRYING TO STREM A MOVIE FROM PHONE OR???ANYWAY IT MIGHT SHUT DOWN BECAUSE IT IS NOT CORRECTLY PLUGGED IN THE RIGHT PLACE LIKE DVDINPUT,OR INPUT FOR HDMI?YOU NEED TO TELL WHAT YUOR DOING OR TRYING TO DO
8/22/2014 8:24:39 PM • JVC HD-52G786... • Answered on Aug 22, 2014
How to replace a lamp on my jvc tv
If you haave the original manual, this is discussed at the start of page 91. If you dont have manual, it can be obtained at books.jvc.com 1. Purchase lamp TS-CL110UAA 2. Turn Off and unplugg set 3. Remove lamp cover located on the left side of TV 4. Remove and replace lamp 5. Reset lamp counter in menu for accurate hour information.
7/28/2014 3:36:35 PM • JVC HD-52G786... • Answered on Jul 28, 2014
3answers
JVC tv model HD56G786
It's easy, you just have to go back into the menu setup for the auto channel/tuner setup and rescan for channels. I'd noticed this as well when playing around with the tv when I'd bought it and it had done the same to me.
7/8/2014 8:35:24 PM • JVC HD-52G786... • Answered on Jul 08, 2014
Hi I have a JVC DLP HDtv that uses a Bulb JVC CL11...
It not the bulb,it still good.Ur tv have a problems known as convergence,"have colors shadows,colors misalinement,picture look like 3D" it dead.This convergence problems it happen to all DLP TVS sooner or later. The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts in the convergence board must be change to fix this.The shop will cost u $300-350 for parts and labors.
5/27/2014 6:01:59 PM • JVC HD-52G786... • Answered on May 27, 2014
Please help!!! Problem with JVC DLP TV
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
5/27/2014 5:59:09 PM • JVC HD-52G786... • Answered on May 27, 2014
When trying to watch the t.v. using cable input,
follow this steps and fix it. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
5/27/2014 2:20:17 AM • JVC HD-52G786... • Answered on May 27, 2014
I am trying to locate the power supply board on
If you have never replaced the lamp then I suspect that first as fans starting up means the power supply is working ok. The lamp may look good but is failing to fire. The part number is TS-CL110UAA.
5/21/2014 10:25:06 PM • JVC HD-52G786... • Answered on May 21, 2014
THERE IS NO SOUND
Try a hard reset by unplugging the set for 30 secs. Then, go into the remote and make sure speakers have not been turned off.
5/8/2014 1:38:51 AM • JVC HD-52G786... • Answered on May 08, 2014
JVC HD-52G786 52" Rear Projection HDTV Logo
188 questions posted
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
when trying watch t v using cable
  • Televison & Video
