20 Most Recent JVC AV-48P575 48" Rear Projection HDTV-Ready Television Questions & Answers
5answers
No sound on JVC AV-48P575 48 inch rear projection TV
Try going into the menu and find something called, "center channel input." If it is on, the sound will not work. Turn it off, and the sound should be restored.
2/16/2020 2:00:30 PM • JVC AV-48P575... • Answered on Feb 16, 2020
Jvc 48p575
If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2380 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/ Disassembel procedure to many brand TVs are given in detail with illustrations.
4/30/2013 11:29:37 AM • JVC AV-48P575... • Answered on Apr 30, 2013
My JVC big screen tv shut off by itself last night. When we turn it on it makes a buzzing sound in the rear and the lamp light flashes, does it need another lamp?
the model indicated here does not have a lamp but, if you suspect the lamp then take it out and have a look at it.....
5/23/2012 1:23:20 PM • JVC AV-48P575... • Answered on May 23, 2012
One of the tubes in
Sir it defends on the part that is damage, sir are you sure that one of the tubes create the smoke? good day and best regards.
9/12/2011 2:21:50 PM • JVC AV-48P575... • Answered on Sep 12, 2011
Screen is getting dim... can
Try to replace it but after you replace the bulb you should reset the lamp hour meter. Feel free to send feed back good day and best regards.
8/17/2011 12:55:41 PM • JVC AV-48P575... • Answered on Aug 17, 2011
TV turns off or gose black then come back on
This is typical with many sets when it goes old as there is a high possibility that the components over a period of heating and cooling , tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs.
Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points. Please remove the SMPS and check as it can have poor solder joints. Look for bloated capacitor in the circuit.If seen replace and check.
6/16/2011 7:27:27 AM • JVC AV-48P575... • Answered on Jun 16, 2011
Lightning hit my house my tv turned off and has
Many years ago I was called to a house in the countryside because their TV wouldn't work. I arrived to discover that the TV looked perfect on the outside but when I removed the rear cover, there was no copper track left anywhere, just components on a bare pcboard. The aerial lead was without a copper conductor and the mains lead thee same. That was a direct hit.
I was called to another set with the condition of dead set. There was no external or indeed internal damage but the electrical surge has damaged the power supply. I repaired the power supply to find a line timebase fault. I repaired that to find a problem with the tuner, I wrote the set off to insurance as a total loss.
One can never tell what or indeed where the damage is with this sort of problem.
Hope that helps and stops you getting a large bill for a repair that may fail again.
11/9/2010 10:02:20 PM • JVC AV-48P575... • Answered on Nov 09, 2010
Some channels have sound, others don't. Picture
Possible that the sound settings are in different modes on the TV. So check to set after selecting the channels to the required sound frequency of your service provider.
If not you will need to reset once again the memory and do a search scan IN the AUTO mode for resetting the TV channels.
11/1/2010 2:13:28 AM • JVC AV-48P575... • Answered on Nov 01, 2010
I need to dismantle my
here are links where you can acquire service manual
which includes diasssembly f the unit
http://tv-solutions.redtienda.net/cat.php?id=57073
Service-Docs.com - Service Manual Make / Model List - I-K
sample image:
9/10/2010 3:35:37 AM • JVC AV-48P575... • Answered on Sep 10, 2010
JVC Model No. AV-48P575. Picture goes all
Ur tv are developing a problems call convergence,it dying.The convergence board the 2 STK convergence ICS,and some or all it resistors are dying.These parts are must be changed to solved the convergence problems.The shop will cost u $300-350 for the parts and labors.
5/21/2010 8:48:17 PM • JVC AV-48P575... • Answered on May 21, 2010
Clicking on the power supply board(no picture or sound)
If you hear a buzzing, humming or rapid clicking noises this could be a problem with your ballast.Might be a good idea though to pull out your lamp just ensure its not damaged.You can find these at discount-merchant.com
4/1/2010 10:42:35 PM • JVC AV-48P575... • Answered on Apr 01, 2010
The picture on the screen in blurry
you might need to see if you can have a tv technician come and clean your mirror and crt guns. and yes universal remote will work fine
3/18/2010 5:49:11 PM • JVC AV-48P575... • Answered on Mar 18, 2010
HDMI is not picking up a signal and the screen is
Be sure to check the connection to the play and TV. This does not happen often since HDMI is a all digital connection so the picture does not degrade as it would with Analog.
Try to switch to a differant play to see if it is the TV or the player. Also try to switch connection to a componet or comosite output to see if the HDMI is or is not the issue.
Send me a comment so I can help you further and to let me know how it goes.
Hope I helped!
3/18/2010 2:26:29 PM • JVC AV-48P575... • Answered on Mar 18, 2010
9answers
HDMI no longer working
JVC AV-48P575 HDMI reset procedure:
1. Unplug HDMI cable from tv.
2. Unplug the tv.
3. Remove the rear (low) back cover.
4. Find the 6 pins on the board of the HDMI module and shortcut the pins no.1 and no.2 using a jumper(i use an old hard drive jumper).That's the higher to pins if you can't see the number.
5. Put back the rear cover.
6. Plug the tv.
7. Turn on the tv.
8. Unplug the tv(without tunrning it off).
9. Remove the back cover.
10. Remove the jumper on the pins 1 and 2.
11. Put back the rear cover.
12. Plug the tv and you're done.
11/4/2009 12:56:00 AM • JVC AV-48P575... • Answered on Nov 04, 2009
2answers
Need Help with tv problem
tiene que revisar la tarjeta de comvergencia
10/22/2009 2:45:19 PM • JVC AV-48P575... • Answered on Oct 22, 2009
JVC AV-48P575 48" Rear Projection HDTV-Ready Television Logo
56 questions posted
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
need dismantle
  • Televison & Video
