20 Most Recent
Xtreme CF Motor Brace (2Pc) Baja 5B Questions & Answers
Kid motorz xtreme quad red 6v ride on Motorcycle won't go forward but will go in reverse. How do we fix this?
Most of these sort of things work in a similar way to mobility scooters, cordless drills, etc.
The motor is generally a dc permanent magnet motor that will run in either direction depending on the polarity of the connections to it. Reversing the polarity and therefore the direction of rotation is accomplished by a switch - with a cordless drill the switch is a manual mechanical switch while a mobility scooter the task is accomplished by relay(s) and semiconductor devices on the circuit board depending on which part is energised by the handlebar control.
I expect your kid's quad bike is similar in principle. In my limited experience the quality of the internal circuitry, the wiring, connections and switching is usually well below what it should be - if you are lucky, you will find a wire has fallen off but the problem could be more complex.
9/5/2019 12:34:48 AM •
Xtreme Toys
Answered
on Sep 05, 2019
Hi I've got a babyweaver
Sounds like you are missing the central support rod or bar that connects the Babyweaver swinging crib to the stand, providing stability and support for the crib. This component is crucial for maintaining the structural integrity of the crib and ensuring safe usage. Here are some steps you can take to address the missing part:
1. Contact the Manufacturer:
- Reach out to Babyweaver or the manufacturer of the swinging crib to inquire about obtaining a replacement central support rod.
- Provide them with details about the missing part and the specific model of the swinging crib to ensure you receive the correct component.
2. Check for Spare Parts:
- Check if the swinging crib came with a user manual or assembly instructions that may have information about spare parts or replacement components.
- Look for any contact information provided for customer support or spare parts inquiries.
3. Online Search:
- Conduct an online search using keywords such as "Babyweaver swinging crib central support rod" or "Babyweaver crib replacement parts" to see if you can find the specific part for purchase.
- Explore baby product retailers, online marketplaces, and specialty stores that offer replacement parts for nursery furniture.
4. Local Retailers:
- Visit local baby product stores or furniture stores that carry nursery items.
- Bring the existing part (if you have one side of the support rod) to help them identify and match the missing component.
5. Custom Fabrication:
- If you are unable to find a suitable replacement part, consider contacting a metal fabrication shop or a carpenter who may be able to custom-make a central support rod that fits your Babyweaver swinging crib.
- Provide them with measurements and details about the required specifications for the part.
3/22/2024 3:29:32 AM •
Toys
Answered
on Mar 22, 2024
I have a new model teddy ruxpin and my 2 year old daughter tripped and dropped him. His lights all come on but his app and sound are not working
It sounds like the drop may have caused some internal damage to the electronics or wiring of the Teddy Ruxpin toy. Here are some steps you can take to try and troubleshoot the issue:
- Restart the Toy: Sometimes a simple restart can resolve minor issues. Try turning off the toy completely, including any power switches or buttons, and then turning it back on again after a few moments.
- Check Battery Compartment: Ensure that the batteries are properly inserted and making good contact with the terminals inside the battery compartment. If the drop caused any displacement of the batteries, it might affect the toy's functionality.
- Inspect for Physical Damage: Carefully examine the exterior of the toy for any signs of physical damage, such as cracks, dents, or loose parts. If there's visible damage, it may indicate internal damage as well.
- Test with Different Devices: If the Teddy Ruxpin toy connects to a separate app or device for sound playback, try connecting it to a different device to see if the issue persists. This can help determine if the problem lies with the toy or the connected device.
- Contact Customer Support: If none of the above steps resolve the issue, it's possible that the drop caused internal damage to the toy's electronics or wiring. In this case, you may need to contact the manufacturer's customer support for assistance. They may be able to provide further troubleshooting steps or offer a repair or replacement option.
Keep in mind that since the toy is relatively new, it may still be under warranty, which could cover repairs or replacements for damage caused by accidents like drops. Be sure to check the warranty information or contact the manufacturer for guidance on warranty coverage.
3/21/2024 2:25:15 PM •
Toys
Answered
on Mar 21, 2024
Fisher-Price J7485 T-Rex stopped moving
Check Batteries: Ensure that the batteries are properly inserted and have sufficient charge. Sometimes, a low battery can cause the toy to stop functioning.
Switch On/Off: Confirm that the toy is switched on. Some toys have an on/off switch or button that might accidentally get turned off.
Connections and Wires: Inspect the wires and connections inside the toy. Loose wires or faulty connections can lead to malfunction.
Obstructions: Look for any obstructions or debris that might be preventing the T-Rex's movement. Clear any blockages.
Reset: If there's a reset button, try pressing it. This can sometimes resolve minor issues.
Contact Customer Support: If none of the above steps work, consider reaching out to Fisher-Price customer support as below.
https://service.mattel.com/us/ContactUs.aspx
2/22/2024 2:51:59 PM •
Toys
Answered
on Feb 22, 2024
Can I fix an error on my orthofix 2212 it shows
Why are you guys giving answers to fix a printer when the OP is asking how to clear the error code on an orthofix bone growth stimulator used to help the bones fuse together after back surgery... I'll give my best guess as I am having the same issue. They are set to last a certain amount of time and designed to stop working after that set time. In my case I got the device, postponed my surgery and my orthofix wouldn't work after I actually had the surgery.. 2nd best guess would be a battery issue because I can charge mine fully, turn it on for about 10 min, put ot back on the charger and it flashes all 4 bars like its completely dead.. but there is a number you can call that can help you more than I can, 18005354492
1/17/2024 9:11:13 PM •
Toys
Answered
on Jan 17, 2024
How ca i overcome my
Tried and tested solutions.
Go out and take deep breath and in your mind say 'I want to get rid of this bad habit"
1/4/2024 6:43:12 PM •
Toys
Answered
on Jan 04, 2024
How to reset my nsfas password because u don't remember it anymore
If you want to reset your nsfas password, here is what you should do.
- Go to www.nsfas.org.za
- Click nsfas account
- Click 'forgot password'
- Type in your ID number
- Choose one of the following options:
- I can't remember my username
- I can't remember my password
- I can't remember my username and password
- Choose the relevant option
- Click 'submit'
- A One Time Pin (OTP) will be sent to you via SMS and email to the cellphone number and email you provided
- Check your cellphone or email for the OTP. This OTP is only valid for 24 hours
- Type the OTP number in the provided block
- Click 'submit'
- A link to reset your login details will be sent to you via email and SMS
- Click on the link that was received through SMS or email
- Follow the reset process
- Create a new password by following the instruction on the screen
- Click 'submit'
And you're done. You should now have a new password set on your nsfas account.
12/25/2023 1:31:19 PM •
Toys
Answered
on Dec 25, 2023
