20 Most Recent Maxent MX-42VM 42 in. Plasma HDTV Questions & Answers
0answers
MX-42VM7
Be the first to answer 10/31/2017 12:21:03 PM • Maxent MX-42VM... • Posted on Oct 31, 2017Be the first to answer
I have a used 42" Maxent flat screen TV that stopped coming on when I turned on the power button. The power light comes on but I have neither sound nor picture. How do I diagnose the problem?
best advice is to take it in for a repair quote but for the price I am thinking that a replacement unit will be a cheaper option
3/15/2016 10:12:29 PM • Maxent MX-42VM... • Answered on Mar 15, 2016
When i turn on tv no picture
need to check or replace main board .
8/24/2013 10:06:35 PM • Maxent MX-42VM... • Answered on Aug 24, 2013
No picture but turns on
the LED lights have burned out
8/24/2013 3:03:40 PM • Maxent MX-42VM... • Answered on Aug 24, 2013
0answers
3answers
Maxent MX-42vm10 42" Plasma
Generally, if a Plasma Tv is not coming out of standby, it means either the main board is faulty (most likely case) or Power Supply Board is not giving enough power to Main board to switch on the TV. In your case, I think it's the main board (aka Motherboard). Sometimes it's hard to tell to whether ceremic fuses are blown off by looking at them, so it's best to check with a multimeter. Check the fuses in the PSU and also whether it's outputing correct voltages. Also, can you hear a clicking noise right after you've switched on the TV or pressed the power button in the remote to make the Tv go from standby to ON. A clicking noise means one of the boards is shorting out. In your case, I don't think you'd hear a shorting out clicking noise, and I think replacing the Main board will get you out of standby.
3/10/2013 4:50:33 AM • Maxent MX-42VM... • Answered on Mar 10, 2013
0answers
0answers
The tv have volumen and the imagen only had three
try to reset the button at the main cpu board it is a small button soldered on tha mainboard pcb.reset the button.to reach the button you need to remove all covering plastic of the monitor.
5/17/2010 8:17:07 AM • Maxent MX-42VM... • Answered on May 17, 2010
2answers
Maxent MX-42VM10 42 Remote
Trying to program a universal remote can sometimes be a frustrating process. Successful programming of a universal remote depends on whether the universal remote manufacturer included our company’s information in the remote when it was assembled.
Then a cable company (ie., Comcast) or satellite provider (ie., Dish Network) orders their decoder box and universal remote control from a manufacturer (ie., Scientific Atlanta, Motorola, etc.), the decoder box manufacturer provides a list of all the possible remote controls this universal can duplicate. From that list the cable company or satellite selects which manufacture’s products to include on their new universal remote. Once those manufacturers names have been decided, they are placed on the universal remote and a numeric code is assigned. If they choose not to include our company on the universal remote, the universal remote may not access the Maxent screen.
If you cannot locate Maxent on the list provided to you by the universal remote provider, please try the following:
Through contact with various cable and satellite content providers we have developed a list of the most common numeric codes that are used with universal remotes.
Content Provider/Most commonly used code
Comcast: 1755
Comcast (ML-3251HLT Model): 0054
Insight: 1755
Direct TV: 11755
Dish Network: 742
Cable Vision: 165
Adelphia: 0156, 1755
Universal: 0762
One4All: 0036
Time Warner: 0230
We have identified other manufacturers of display products that have similar remote control information to ours. Depending on the universal remote you are using these manufacturers may work. Please use the documentation that accompanied your universal remote, and look up the following companies. Input the numeric code associate with that company.
Gateway
Sampo
Viewsonic
Magnavox
Phillips
Marantz
Pilot
If the universal remote you are trying to program contains a Code Search (the remote will scan through all the codes contained within the universal remote) function, we recommend that you try that procedure. It is possible that there may be another manufacturer code that may work with our monitor.
You may also want to try a Learning Remote from another manufacturer. This type of remote control can absorb or record the information coming directly out of the Maxent remote control. The learning remote then duplicates that information and acts like the Maxent Remote control. This type of remote can also record the signal coming from your other universal remotes in the same manner. In which case you can use this learning remote for your entire audio video system
1/31/2010 8:29:42 PM • Maxent MX-42VM... • Answered on Jan 31, 2010
Maxent MX-42VM10 42 I have sound but no
i can get sound but no pic can u help 42vm
8/23/2009 3:01:25 PM • Maxent MX-42VM... • Answered on Aug 23, 2009
I need the remote control for this TV. do you
walmart, dollar store, target, radio shack, ebay, craigs list.
6/8/2009 8:25:06 AM • Maxent MX-42VM... • Answered on Jun 08, 2009
0answers
Maxent MX-42VM10 Plasma Screen TV and the 60 gig Playstation 3
yes it will
1/1/2009 12:41:22 AM • Maxent MX-42VM... • Answered on Jan 01, 2009
Maxent MX-42VM 42 in. Plasma HDTV Logo
Popular Tags
34 questions posted
Top Maxent Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Maxent Televison & Video
Most Popular Question
maxent mx 42vm10 42 remote
  • Televison & Video
