20 Most Recent JVC AV-27850 27" TV Questions & Answers
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
JVC AV-27850 27"... | Answered on Jun 04, 2016
Contact the authorized service center for JVC.
JVC AV-27850 27"... | Answered on Oct 07, 2013
replace flyback transformer
Check and replace its tuner.
JVC AV-27850 27"... | Answered on Aug 25, 2013
Mr. York, you give very little information, but from what I gather. All Tv's have the ability DISPLAY the channel all the time or for a short time after changing. GOTO menu or display button on the Remote control [r\c] and you should see that the time display can be change.
JVC AV-27850 27"... | Answered on Nov 01, 2011
Remote won't workThe most common reasons the remote won't work is that the batteries are dead or it hasn't been programmed properly. It's often easy to fix. Here are the steps to take to troubleshoot the problem.
Make sure you have a clear path between the remote and the infrared eye on your equipment. Clear any dust or debris that may be covering the eye.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Press the SAT mode button at the top to unlock it. Your remote should work properly.
Check the batteries. When you press a mode button, does it light up? If not, you may be out of juice. Check to make sure they are in the right way, with the metal ends making good connections with the metal in the remote. If they're in correctly and you still don't get power, try replacing them. They may be dead.Learn about batteries
Check to make sure the remote is programmed properly, which basically means you reprogram it to work with your receiver, TV and any other components. Start with the receiver and work your way through programming each component that isn't working. We tell you how to program remotes in our guide to remotes.Learn about remotes
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.Be prepared to tell us:What components you have.All of the steps you've been through to try and solve the problem yourself.Can't change channels on receiverThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Make sure you are in SAT mode. The receiver will only change channels when the remote is in the correct mode.Look for a timer. If you have a timer set, the receiver won't let you change channels. This ensures you don't miss recording a program with an external device. If a timer is set and you want to watch another channel, simply turn off the receiver and turn it back on.Learn about timers
Make sure the problem is with the remote and not the receiver. Try the buttons on the front of the receiver. Try to change channels. If your model doesn't have channel buttons, try to turn the machine off. If you can't change channels or power off, the problem is with the receiver. Try unplugging it for two minutes and plugging it in again.
If you can change the channels or power off, the problem is with the remote. Press any mode button on the remote. It should light up. If not, you probably have low batteries. They should be replaced.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Click on any of the mode buttons at the top to unlock it. Your remote should work properly.
Try re-programming the remote to talk to your receiver.Find the manual for your remote control
Check to see if your Shaw Direct Receiver is using the same remote control address as your remote control.If you are using the DSR 319, HDDSR 505, or HDPVR 530 receiver press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate to 6 - System Setup and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 4 - System Setup. Then 3 - Installation Settings. Followed by 2 - Remote control Address.If you are using a legacy receiver such as the DSR 315, DSR 405, or any other receiver with front panel buttons, press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate OPTIONS and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 6 - Change System Settings. Then 3 - Change Installation Settings. Followed by 2 - Set Remote Control Address.Follow the on-screen instruction to reset the remote control address on your receiver and remote control.Check the back of your remote, if you own the IRC/URC 550 or RT-U50 remote controls you will need to enter the remote control address differently from what is displayed on screen. To program these remotes, hold the ENTER and MUTE button on your remote at the same time until the mode buttons at the top start to illuminate then enter the last three digits of the number displayed in "Current Address" column on the screen, then press the MUTE button to lock in the code. For example: If the remote address on the screen displays 0002, you would hold ENTER + MUTE until the mode button illuminated and then enter 0 0 2, followed by ENTER on your remote control.If you own the IRC 551 or URC 551 remote control you can follow the instruction depicted on the screen, but you must substitute the follows numbers in place those specified: 00869 for 0000, 01870 for 0001, 01871 for 0002, 01872 for 0003, 01873 for 0004, 01874 for 0005, 01875 for 0006, 01876 for 0008. For example: If the remote address on the screen displays 0003, you would hold the SAT button until it flashes, press 01872, then ENTER, to lock in the new code.Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Can't control TV volumeThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Press the volume button on the remote. The TV mode should light up. If not, you probably have low batteries. They should be replaced.
If the SAT button lights up, you are in the wrong mode. Press TV and try again.
Try re-programming the remote to talk to your TV.Find the manual for your remote control
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Thank you for using Fixya, Hope this will help your problem.Don't forget to rate me.thanks,Reymond
JVC AV-27850 27"... | Answered on Oct 19, 2011
Hello
There is no mention about the language selection on this device's user manual. You may have to reinstall the software I thinks. If you wants its manual send me a mail to my email address given below.
gopakumarg43@ymail.com. The manual is in Adobe Acrobat Reader format. OK.
JVC AV-27850 27"... | Answered on Jan 11, 2011
Hello
The Plug In Menu comes up automatically when you first turn on the TV after plugging it in. The
Plug In Menu helps you to get your TV ready to use by letting you set your preferences for:
• The Language in which you want the onscreen menus to appear,
• The Auto Tuner Setup of which channels you wish to receive,
• Setting the TV's clock to the correct time so your timer functions will work properly.
Descriptions of each of the Plug In Menu features appear on this page and the next.We recommend
you complete the Plug In Menu setup first so your TV is set up just the way you want,
right away.
Introduction
Auto Tuner Setup
Language
You can choose to view your onscreen menus in three languages: English (ENG.), French
(FRAN.), or Spanish (ESP.).
Press the MENU button
Press UP or DOWN To LANGUAGE
Press RIGHT or LEFT button to choose a language
You will not need to press the MENU button to enter this screen from the Plug In Menu.
OK
JVC AV-27850 27"... | Answered on Dec 26, 2010
Sorry this things not in production anymore.Try Ebay.com might able to buy some body sell these refurbish part.
JVC AV-27850 27"... | Answered on Jun 19, 2010
This seems Close Caption is On in your tv.
Please turn Off Close Caption by pressing CC button on tv remote.
Let me know if you have additional question, please also mention model number of tv.
Thanks.
JVC AV-27850 27"... | Answered on Apr 24, 2010
Encompass Parts might can get you one they do list it but dont have any in stock right now Call 1-800-638-3328 they list owners manual and instruction Book CQ-40343-A01-A and INS Book CQ40343-001-A
Go to menu then setup Look for close captions turn it ON or Try UED see if they have Book 1-800-648-6657
JVC AV-27850 27"... | Answered on Dec 03, 2009
Quick solution:
Weigh yourself on a scale. If you can, pick up the TV and step on the scale again. The difference between the two readings is the weight of your TV.
JVC AV-27850 27"... | Answered on May 16, 2009
try this:
Click "Display" and "Picture Mode" simultaneously this worked on my jvc av-25lx14
if it didnt work or if you dont have those buttons then try this:
click on "Muting" and "Info(its the button that has the"i" symbol"
Good luck
Sila Awad
JVC AV-27850 27"... | Answered on May 23, 2008
Sounds like a capacitor and/or the Vertical amp Ic has gone out in the set. Maybe a bad solder joint. Depending on where you live, the cost of repair could be between $100.00 to $150.00. Kill it or what? What would Braveheart do. FFFRRRREEEEEEEDDDOOOMMMM
JVC AV-27850 27"... | Answered on May 03, 2008
Needs convergence IC's replaced..........T.
JVC AV-27850 27"... | Answered on Dec 22, 2007
generally buttons are located at front only. but if it is not there then it will be inside in the shape of small variable res. called preset. vertical hold button will be near vert.section &horz hold near h/ section.
JVC AV-27850 27"... | Answered on Sep 30, 2007
JVC would be a possible source.
JVC Televison &... | Answered 3 days ago
it needs service,
or buy the service manual and read.
sound like the power supply inside is bad or the lamps back light.
ask here
http://www.us.jvc.com/support/
JVC Televison &... | Answered on Sep 16, 2019
Televison & Video Logo
20 questions posted
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
get flyback transformer jvc av27850
  • Televison & Video
