20 Most Recent JVC AV-27120 27" TV Questions & Answers
I need a solution for this problem..I can't get the tv to come on to go into the menu and clear the timer...Someone have any helpful info...I have the comcast box on the tv..I took everything off the tv
and plugged it in thinking atleast the snowy screenwill come up and then I could see the menue and fix the timer but that didn't happen. Left tv plugged in and cable hook ups on figured eventually the timer would clik off and tv would come back on..No such luck....Can anyone help me with this problem
JVC AV-27120 27"... | Answered on May 12, 2011
Please follow this guide to unlock your tv :
www.ehow.com/how_4488981_unlock-tv.html
Regards, Jay__PMNBRVC
JVC AV-27120 27"... | Answered on Feb 21, 2011
The codes in the owner manual don't work not any codes out here will help u.Return the universal remote.Try website like Remotes.com to buy an exact remote as original remote,might have some new JVC codes u could tries,but not likely it will work either.
JVC AV-27120 27"... | Answered on Feb 02, 2011
Hello
You just do autotune to receive all channels. In this mode TV will tune through the entire channel band automatically, and finally will stop tuneing, and will show the first channel receved. You must be patient for these time. about two or three minutes, without disturbing is process. The tuning process follows.
Auto Tuner Setup
In Auto Tuner Setup, the TV automatically scans
t h rough all available channels, memorizing the active
ones and skipping over blank ones or channels with
weak signals. This means when you scan (using the
CH A N N E L +/- b u t t o n s ) you will receive only clear,
active channels
P ress the ME N U b u t t o n
Press UP or DOWN buttonTo AUTO TUNER SETUP
Press Right or Left button to operate
Press Vol+ or Vol (--) to choose CABLE or AIR
Press UP or DOWN button to move to START
Press Right or Left Button to start Auto Tuner Setup
Tv will show "NOW PROGAMMING" display.
Programming will take approximately 1 to 2 minutes.
After all it will show
PROGRAMMING OVER
Some cable systems experience interference from radio frequencies on cable Channel 95. You may delete this channel from
your scan by removing the "X" next to it on the Channel Summary screen.
JVC AV-27120 27"... | Answered on Nov 29, 2010
in ur tv you have two circuit boards x and z the are not running in sync this causes this problem just had mine reboarded hope this is help to you
JVC AV-27120 27"... | Answered on Nov 01, 2010
If you're NOT still under warranty you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. good luck!
JVC AV-27120 27"... | Answered on Dec 18, 2008
the problem of ur tv is tuner,try to solder the tuner
JVC AV-27120 27"... | Answered on Sep 28, 2008
the control must have broken or contact or print must have demaged due to more pressure on button. please call tech to fix it.
JVC AV-27120 27"... | Answered on Oct 04, 2007
You have whats called a verticle sweep falure. This is a componet falure and not something a handy-person should attemt to repair as theres some electronic troubleshooting involved, and some very high voltages inside the set. This happens to be a nice set, and if it was mine, I would invest the 100.00 150.00 to repair this set. Good Luck
JVC AV-27120 27"... | Answered on Jun 10, 2006
JVC AV-27120 27" TV Logo
12 questions posted
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
tv problems
  • Televison & Video
