20 Most Recent
JVC AV-36260 TV Questions & Answers
How do you reset forgotten parental control password?
Disconnect power to the TV. The power interruption will allow you to reset the parental control password to the default password of 0000.
To change the password after disconnecting the power, do the following:
1. Press the Menu button on the remote.
2. Arrow up / down to SET LOCK CODE
The lock icom will appear
3. Arrow left / right to operate
4. Press 0 to access the lock code
5. The first digit will be highlighted.
Arrow left / right to select the number
Arrow up / down to move to the next digit
4. Continue to follow these directions for all 4 code numbers.
5. Arrow up / down to FINISH
6. Arrow left / right to save settings and exit.
The password has now been reset.
I have forgotten the parental password for my acer
Just take out the battery. Open the laptop, and take out the bios battery, which can be located very near to bios IC. This will make the bios to factory reset. Insert the bios battery after 5 minutes or so. Re-assemble the laptop. Attach main battery, and switch it on. Press 'Delete' button, while the O/S loading. This will lead you to its bios adjust screen. do necessary adjustments, select 'Save and exit' option. the laptop will restart with no password, after that, you can insert it if you want.Another method is to re-install the O/S. If you wish to get more details about how to disassemble the laptop, check the site linked here.
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and press '
Enter'
or view it in
Mosaic / Timeslide option. Bios battery will look somewhat like this.
TV look like the red goes on and on. blurry. tried adjusting color but does not seem much better
Check the video output section circuit for any loose solder terminals. This section can be located at the neck of the picture tube. It will be plugged on to it. A rectangular printed circuit board, have some components soldered on it. Check the solder terminals of these components for any loose contact. Take a special care to 'Red' output section. It will be best to resolder all the suspected solder terminals by applying a little more fresh solder, without making any solder bridge short in between adjecent solder terminals. If you want any more details, visit this site "Electro-help".
Tv comes on then black square pops on screen
HelloClosed caption option is "ON". Just turn it 'OFF' If the remote control of your tV has a "CC" button. press it once. If it has't that button, you have to enter its Menu option, surf through, and come to closed caption function window, and select the closed caption OFF.
The red power light is
This sounds like an internal problem and most likely something is broken in the circuitry inside.
Unfortunately this can be anything from a fuse to a capacitor to a short.. or even bad hardware, all of which depend on the TV model and type.
As a good test with most electronics, try to defuse the power remaining (lingering) inside by unplugging the TV and with no power going to it - hold down the power button for about 5 -10 seconds and then release and wait about a minute (as a good rule to do with all electronics). After plug in and see what result you get. If the same problem exists, you can usually remove problems such as bad circuitry. (But, not always)
If you have a manual, sometimes the best thing to do is read any trouble shooting they have listed and see if you find the same problem, and lastly. Call the manufacture.
Wireshark Cookie Dump:
OKCancel
I lost the remote to
The tv some how it on Close Captioning modes 1,2,3 or Text 11,2,3 is on that why have the big black box is on the screen.Go to your tv menu look for Close Captioning functioning 1,2,3 or Text functioning 1,2,3 turn it all to off.The black boxes will disappear.
Lost picture and controls
Check first the power of your tv ,maybe theirs sort circuit on the regulator ic ,then replace it with the new one...
The screen has lost the brighness. I can't make it
ok, thanks for clarifying.
it might be a connection problem with the RGB connectors (im not sure of the exact part name, sorry) inside the TV.
DO NOT OPEN THE TV YOURSELF!! you could be electrocuted.
I suggest you bring the TV in, try to get a free estimate first.
I hope this helps.
JVC AV-36260 TV Problem TV won't turn on
I have over 10 years experience in electronic tech support.
I
know this isn't what you want to hear, but the problem you've described
can't be fixed with troubleshooting. Your TV will have to be repaired.
There is a part that has developed a defect and needs to be replaced. The blinking red light is like an error message that indicates to a service tech what's going on with the set. If
you're still in warranty, the TV will be repaired at no charge to you.
The warranty would likely be at least one year from the date of
purchase from the manufacturer. If you purchased an extended service
plan they will repair the TV at no charge as well.
If
the TV is no longer in warranty, it will likely cost a minimum of $150
parts and labor. This is assuming that you only need a power supply
module. If the problem is more than one of the circuit boards, the price of
repair could go much higher.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from here.
Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
- blowing fuse is a short circuit problem in your tv.
- please do not replace fuse unless you know the reason otherwise it may damage tv.
- fuse blowing is due to
- main filter capacitor
- power output transistor sort or regulator short circuit.
- good luck
Dropped tv and now i only get purple and yellow as the tv colors
hi..It sounds like your tube Shadow Mask may have got
magnetised and need to be degaussed.turn off your TV
at the mains and unplug it for at least two three hours,
after that time power up your TV it should degauss the
tube at power up.
try this out..
thank u..
kindly rate my response..
'03' is displaying on my screen
First try, using the remote, pushing the display button until the display is turned off (three to four depressions on the remote display botton. Second try, unplugging the tv for at least 2 minutes then plug the tv back in. This should reset the tv if you have lost the original remote with the display bottton.
JVC projection screen with blowen fuse
You have to check the reason , why the fuse blew. It is something else that made the first fuse blow. The fuse has nothing to do with picture after the TV starts up.
Jvc tv
picture tube may be busted...check it it might need replacement
