20 Most Recent JVC AV-27S33 27" TV Questions & Answers
JVC AV27S33 tv black and white
I would guess you are using an antenna or a cable service without a set-top box. When the TV is using HDMI or component video it does not employ the decoding for the color as like when using an RF feed. Most people of today do not use RF directly in to their TV set using the built in tuner. They feed a desk-top box that feeds a decoded picture in to the set via the component RGB connectors, or they are using HDMI. When viewing an RF signal from the antenna or cable using the TV's internal tuner, check the video settings. make sure the setting for Color is turned up to 50% of its range to start with. If there is no color, check to make sure the Settings are correct. Check to see if the TV has a black and white mode, and this mode is turned on. Check to see if the TV receiver section is for your location type. If you have a set from another country that uses another broadcast system for color this can be an issue. It is also possible the TV set's color decoder for RF reception is defective. This would require proper service. You would not be able to service this yourself. Based on the info you supplied these are the best suggestions I can think of...
3/11/2017 4:03:50 AM • JVC AV-27S33 27"... • Answered on Mar 11, 2017
Turns on with green screen then turns off
Displaying greens screen is a bad symptom indeed. You should suspect its display paneel. Contact any service technician, and make it sure.
11/30/2013 3:44:47 PM • JVC AV-27S33 27"... • Answered on Nov 30, 2013
manual
JVC AV-27S33 only displays black and white (Color gone) Menus are still in color!
Check its color system adjustments. It will be best to make a factory reset to this set. Just unplug the TV from AC mains wall socket, and re-plug it after 10 minutes of so. This must make your TV a hard reset. If this do not help you, the chroma section circuits of your TV need to be checked for fault/s. This is a skilled work, and it will be best to contact any experienced service technician.
7/5/2012 2:48:45 PM • JVC AV-27S33 27"... • Answered on Jul 05, 2012
I have a JVC VCR/DVD
Turn the tv on now see if the tv colors changes to a different colors,not make fist with one of ur hand bang the tv bazel of the tv frame.If the tv colors changes and flashes.Than the tv video board that the board connected to CRT(-tv tube) for tv video picture the video board have to be check out for lose and cold soldering pins holes joint on the video board connections between the video board and the CRT-(tv tube) together.Must be resoldering for a tight and good connections between them to solved this problems.Take the tv aparts.U have a soldering iron and a roll of solder.A resoldering job will fixed this problems if bang on tv bazel frame changes colors.
8/27/2011 11:31:37 PM • JVC AV-27S33 27"... • Answered on Aug 27, 2011
Dark picture, green screen
This could be several things. At its best you have an open resistor near the flyback. You may have a bad ground on a color output transistor, or a bad ground on a color output resistor. These are located on the small board connected to the CRT. In really bad cases you may have replace the transistors, or resistors. But in worst cases, and I do believe its true, you have a bad picture tube. I would not recommend a repair. I have seen this problem with many, many TVs of any brand. You are smarter to purchase a new TV. Thanks for asking and show all hands of support!
6/9/2011 5:17:49 AM • JVC AV-27S33 27"... • Answered on Jun 09, 2011
Blue Screen
I just wanted to suggest some things for you to try, if you have not done them already. Try hooking up a known good signal, such as the main input cable from your cable or dish, hook it straight to your tv, and see if you can change channels, and get a picture on low band...2 thru 6, and then if not, how about any picture above channel 6, if you get picture on 2 thru 13 now, it could be whatever you have hooked in between the input cable and the tv...be sure you have the tv on the right channel for your receiver, usually 3 or 4, or if you are using another type of video input cable, make sure you have tv on the right input for that cable and that cable is good...check the in and out of your component unit, for correct cable hookup as well as your cables, in reference to using RCA video and audio left and right in and out...a lot of sets and vcr's will go to a blue screen if they lose signal to them....I hope this helps you out some.If you cannot get a picture from hooking your signal straight to your tv, it could be the tuner got a spike from a thunderstorm, or has lost the B Plus source for the tuner circuit. Be sure that it is not selected for an input signal,other than the cable or antenna mode, the onscreen text should verify this, if you can change channels with or without getting video...a picture....Good luck with it. T.
2/12/2011 9:02:04 PM • JVC AV-27S33 27"... • Answered on Feb 12, 2011
When I do an autoscan to program channels, it will
It sounds like thats the maximum number of channels it can tune or you are probably scanning either analog/digital channels only. Is the model number that you have listed correct?
8/22/2010 5:17:47 PM • JVC AV-27S33 27"... • Answered on Aug 22, 2010
Picture turns completly purple after being turned on
Sorry to tell you this, but that's one symptom of a bad picture tube. After it's warmed up a little, one of the elements in the neck touches something it shouldn't and you see the result. There's no repair except a new tube, and that's completely uneconomical. It would be less expensive to replace the set.
3/23/2010 6:00:42 PM • JVC AV-27S33 27"... • Answered on Mar 23, 2010
My JVC AV-27S33 is seet up for English but
please turn off the sap mode thats the second audio play mode in this case for spanish
12/16/2009 8:29:20 AM • JVC AV-27S33 27"... • Answered on Dec 16, 2009
JVC AV-27S33 27" Picture
I've found several bad solder joints on the neck board of my JVC 32' leading to the exact same issues as yours. Inspect the Driver resistor solder on the neck board.
9/19/2009 1:04:36 AM • JVC AV-27S33 27"... • Answered on Sep 19, 2009
2answers
Black Menu Appears
set is in the text mode.
3/23/2009 3:50:00 AM • JVC AV-27S33 27"... • Answered on Mar 23, 2009
2answers
Dark picture
**WORKS**
In my case, the adjustment was available from outside the TV. Sortof. On the rear of the TVabout 2 inches to the right of the coax in, there are two vertical slits on a little protrusion. Inside the slits are the two adjustment screws. The lower screw adjusts brightness, the upper screw adjusts focus.
3/23/2009 12:44:40 AM • JVC AV-27S33 27"... • Answered on Mar 23, 2009
Greeish Tint Color
Have you move the tv or is there a speaker that you might have move close by the tv?
turn the tv off for an hour and turn it back on see if the degaussing can correct ir other wise it may have a bad connect on the degaussing or you have some kind of magnetic device close by.,
6/7/2008 4:40:26 PM • JVC AV-27S33 27"... • Answered on Jun 07, 2008
4answers
No color
Does it have a video input? Does it have color when playing a vhs tape or dvd into the video input?
Does the set show the raster lines? Is there any snow showing on the raster?
If the set does not show color with an a/v input either then it is likely the main power supply section feeding the deflection system or the video processing is bad.
RCA sets more than a few years old are not good investments for repairs, unfortunately.
Let me know the answers to the questions above and I can give you a more precise suggestion.
 Good Luck
Was this solution helpful? Show your Appreciation by rating it:
2/2/2008 3:53:33 PM • JVC AV-27S33 27"... • Answered on Feb 02, 2008
JVC 43" (109cm) HD Ready Plasma TV PD43N30A. Chunghop universal remote codes for JVC pd43n30a
Question edited for a lot more clarity, plus Chunghop not chungCHOP :>D JVC: 089, 161, 909
CHUNGHOP Universal Remote Control Codes
codesforuniversalremotes.com https://codesforuniversalremotes.com > chunghop-univer... Jul 25, 2019 - CHUNGHOP Universal Remote Control Codes ; Aiwa: 009, 057, 058 ; Samsung: 618, 619, 620, 621 ; Philips: 013, 023, 024 ; Hisense: 676, 677, 707, 898
3/20/2024 5:38:12 PM • JVC Televison &... • Answered on Mar 20, 2024
2answers
My jvc smart tv is not passing the android logo how do i fix
try unplugging the unit. Press and hold power button for 10-20 sec's then try again
3/17/2024 3:32:51 AM • JVC Televison &... • Answered on Mar 17, 2024
JVC I Art Pro AV-56WP74. It has a cracked outer screen and I can't find anywhere to replace it. I want to fix the problem.
Question edited for clarity. If is is the outer clear screen, replace it with a a sheet of Lexan Polycarbonate sheet cut to size. Lexan is bulletproof. https://www.google.com/search?q=clear+polycarbonate+sheet+cut+to+size Sears list it but no longer available. After all Rear Projection Televisions are antique dinosaurs. Technology has moved on :>D https://www.searspartsdirect.com/model/33xrqyx4kj-001758/jvc-av-56wp74-television-parts https://www.google.com/search?q=jvc+i+art+pro+av56wp74+parts Service Manual https://www.manualslib.com/manual/2744485/Jvc-Av-56wp74.html#manual ..
11/10/2023 11:43:38 PM • JVC Televison &... • Answered on Nov 10, 2023
I have Jvc receiver RX-5060 is not switching on, it is always on standby
  1. Reset the receiver: To reset your JVC RX-5060 receiver to its factory default settings, switch off the receiver and unplug it from the power outlet. Press and hold the "Power" button on the front panel for approximately 5 seconds.Then, while still holding the "Power" button, plug the receiver back into the power outlet2.
  2. Check the fuse: If your receiver still doesn't turn on, check if there's a blown fuse in the receiver.If so, replace it with a new one of the same rating3.
If none of these steps work, it's best to contact a professional or JVC's service center for further assistance. I hope this helps!
8/27/2023 7:04:23 PM • JVC Televison &... • Answered on Aug 27, 2023
My JVC TV has an onscreen remote that doesn't let us use the actual remote what do I do to gat it out?
Hello! If your JVC TV is displaying an onscreen remote and you're unable to use the actual remote, you can try the following steps to resolve the issue:
  1. Power cycle the TV: Turn off the TV and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This can often reset any temporary issues and restore the functionality of the actual remote.
  2. Replace the remote batteries: Check the batteries in your remote control and make sure they have enough power. If the batteries are low, replace them with fresh ones and try using the remote again.
  3. Check the remote control sensor: Ensure that there are no obstructions between the remote control and the TV's remote control sensor. Clean the remote control sensor on the TV with a soft, lint-free cloth to remove any dust or debris that may be interfering with the signal reception.
  4. Reset the TV to factory settings: If the issue persists, you can try resetting the TV to its factory settings. Keep in mind that this will erase any personalized settings and restore the TV to its original configuration. Refer to the user manual or the manufacturer's website for instructions on how to perform a factory reset on your specific JVC TV model.
  5. Contact JVC customer support: If none of the above steps resolve the issue, it's recommended to reach out to JVC customer support for further assistance. They will have access to more specific troubleshooting steps and can guide you through the process of resolving the issue with the onscreen remote.
Keep in mind that the exact steps and options may vary depending on your specific JVC TV model. Refer to the user manual or contact JVC customer support for model-specific guidance.
7/2/2023 4:31:45 PM • JVC Televison &... • Answered on Jul 02, 2023
JVC AV-27S33 27" TV Logo
16 questions posted
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
dark picture green screen
  • Televison & Video
