20 Most Recent
JVC AV-27D305 27" TV Questions & Answers
Sound fades in and out
Check its speaker. If found OK, check and replace damaged component/s in the audio output circuit.
How do I take the
If you have the original remote, there's a button that controls caption settings (I think it's marked "CC" or "captions"). Press it to cycle through the choices until you turn captions off. You may also be able to turn off captioning through the on-screen menu using front panel buttons on this model.
Tv to dark cant see nothing tv's to dim
On the back of the TV, to the right of the I/O panel, there are 2 vertical slot shaped openings on a raised bit of the plastic case. Behind the lower slot is the screen adjuster. Using a phillips screw driver, turn the adjuster clockwise to increase the brightness. Behind the upper slot is the focus adjuster.
My tv has the menu on screen and just continuously
I had this same exact problem with another brand LCD panel. The logic board ended up being replaced. I tried personnaly disconnecting everything that could have input commands (IR reciever for remote, buttons on the TV itself).
-=/ Daft Tech /=-
The remote turns on green light at the bottom, tv
Most likely you have a shorted diode and transistor at the on/off relay inside the set. The trasistor is a small suface mount and the diode is a top mounted device. This should not be a real expensive repair. Take it to a repair shop. These parts are very small.
JVC TV
u need to adjust contrst settings
TV converter Box
yes it will require a converter box if you don't recieve cable or satellite
