20 Most Recent
Dynasty Leisure Bay Dynasty Spas Questions & Answers
Hot tub just get hoter wont shut off when it
It sounds like your heater relay is stuck. You can test this by unplugging the pump that is supplying the water to the heater. If your heater is still getting voltage then replace the heater relay on the circuit board. If you don't have a volt meter, with in a few seconds of unplugging the pump you will start to hear the water boil inside of the heater housing. DO NOT let the water boil for very long. This late in the year you shouldn't be experiencing any connectic heating issues.
Hi we can't get the
Hi
The spa has 3 possible modes,
which can be programmed by pressing the mode key once and then immediately
pressing the up temp key and immediately pressing the mode key. Repeat this to
display one of the following:-
SLP - Sleep Mode - Unit kicks on
for filtration, but heater only comes on when 2o degrees below temp setting.
STD - Standard Mode - unit kicks
on every 30 minutes to sample temp and turns on heater if needed.
ECN - Economy Mode - Unit kicks
on for filtration periods only and heater comes on as needed only during
filtration.
Please get back to us if you have
further query else please accept this particular suggestion.
Thanks for contacting fixya.com
I was given an older spa and in the process on
I think you were told that by someone who was taking into consideration the room needed to drain the spa and the clearance needed for the drain plumbing.
But you can rest the spa on the ground but I would at least put down some type of barrier between the fiberglass and concrete.
Fiberglass is very soft compared to concrete
Hi I've got a babyweaver
Sounds like you are missing the central support rod or bar that connects the Babyweaver swinging crib to the stand, providing stability and support for the crib. This component is crucial for maintaining the structural integrity of the crib and ensuring safe usage. Here are some steps you can take to address the missing part:
1. Contact the Manufacturer:
- Reach out to Babyweaver or the manufacturer of the swinging crib to inquire about obtaining a replacement central support rod.
- Provide them with details about the missing part and the specific model of the swinging crib to ensure you receive the correct component.
2. Check for Spare Parts:
- Check if the swinging crib came with a user manual or assembly instructions that may have information about spare parts or replacement components.
- Look for any contact information provided for customer support or spare parts inquiries.
3. Online Search:
- Conduct an online search using keywords such as "Babyweaver swinging crib central support rod" or "Babyweaver crib replacement parts" to see if you can find the specific part for purchase.
- Explore baby product retailers, online marketplaces, and specialty stores that offer replacement parts for nursery furniture.
4. Local Retailers:
- Visit local baby product stores or furniture stores that carry nursery items.
- Bring the existing part (if you have one side of the support rod) to help them identify and match the missing component.
5. Custom Fabrication:
- If you are unable to find a suitable replacement part, consider contacting a metal fabrication shop or a carpenter who may be able to custom-make a central support rod that fits your Babyweaver swinging crib.
- Provide them with measurements and details about the required specifications for the part.
3/22/2024 3:29:32 AM •
Toys
Answered
on Mar 22, 2024
I have a new model teddy ruxpin and my 2 year old daughter tripped and dropped him. His lights all come on but his app and sound are not working
It sounds like the drop may have caused some internal damage to the electronics or wiring of the Teddy Ruxpin toy. Here are some steps you can take to try and troubleshoot the issue:
- Restart the Toy: Sometimes a simple restart can resolve minor issues. Try turning off the toy completely, including any power switches or buttons, and then turning it back on again after a few moments.
- Check Battery Compartment: Ensure that the batteries are properly inserted and making good contact with the terminals inside the battery compartment. If the drop caused any displacement of the batteries, it might affect the toy's functionality.
- Inspect for Physical Damage: Carefully examine the exterior of the toy for any signs of physical damage, such as cracks, dents, or loose parts. If there's visible damage, it may indicate internal damage as well.
- Test with Different Devices: If the Teddy Ruxpin toy connects to a separate app or device for sound playback, try connecting it to a different device to see if the issue persists. This can help determine if the problem lies with the toy or the connected device.
- Contact Customer Support: If none of the above steps resolve the issue, it's possible that the drop caused internal damage to the toy's electronics or wiring. In this case, you may need to contact the manufacturer's customer support for assistance. They may be able to provide further troubleshooting steps or offer a repair or replacement option.
Keep in mind that since the toy is relatively new, it may still be under warranty, which could cover repairs or replacements for damage caused by accidents like drops. Be sure to check the warranty information or contact the manufacturer for guidance on warranty coverage.
3/21/2024 2:25:15 PM •
Toys
Answered
on Mar 21, 2024
