20 Most Recent
JVC TH-A35 System Questions & Answers
Unlock code for jvc dvd
hi if you can help me i have a dvd jvc th-a35 and it wont play all the dvds what is the number or how i can unlock to play all dvds
When the sound go up
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition specially when the volume is high . This can be also due to LOW VOLTAGE/LOW CURRENT to the amplifier and so when the need is insufficient it can shutt down. So use a voltage stabiliser is mains voltage is low
Also check the speakers resisitance after disconnecting the speakers
Thank you for using Fixya
The DVD player seems to
You have an internal mechanical switch/sensor which failed and will need replacement.The reason it is giving this message because the sensor might have been stuck in a position when it was damaged. And also along with it some parts(semiconductors and capacitors needs to replaced too)need some checking too.
I used to use my
Welcome to FixYa
Dear User
This Guide can Help you to Configure your Device Properly.
Click
here to Read/Download the Guide[You should need Acrobat Reader to View this Guide-You may Download from
Here ]
Thanks for Connecting FixYa
Xbox 360 problem
Umm dude this is due to the fact that the Xbox 360 does not transmit 5.1 surround sound through optical leads you have to use standard red/white cables
