20 Most Recent Gates 2008 Dodge Grand Caravan Accessory Belt Idler Pulley 08 Dodge G Questions & Answers
I have miss fire on cylinder#5 and random misfire I chang plugs wires ign. coil and still misfire 08 dodge grand caravan
have you had the OBD codes read , if not i'd have that done , note the codes , if any , clear them, as claering the codes can sometimes be all that needs doing , if no change post the codes and will be able to locate the sensor/switch causing the issue , another thing to check would be the compression in that cylinder , if low then investigate from there ie valves , head gasket etc
7/23/2015 5:56:19 PM • Gates 2008 Dodge... • Answered on Jul 23, 2015
How does the iPod Nike running monitor work?
The Nike GPS monitor fits into your sneaker and you can track your progress on your iPhone or iPod with a special app. You can download the app from the iTunes app store.
http://nikerunning.nike.com/nikeplus/v1/pdf/English.pdf
11/25/2014 12:13:15 PM • Running • Answered on Nov 25, 2014
Can you put running shoes in the washing machine if they are air?
I have always washed my sneakers in the washing machine, if they have air bubbles make sure that you wash them on a cold wash and not too hot as this can cause the bubble to expand and rupture.
1/13/2013 12:44:04 PM • Running • Answered on Jan 13, 2013
My Nike air max bubble has burst can this be repaired?
It is unlikely that the bubble can be repaired but Nike does have a 2 year warranty depending on the wear and tear of the shoe, you could take them to the store you got them and see what they say.
1/13/2013 12:43:22 PM • Running • Answered on Jan 13, 2013
Gates 2008 Dodge Grand Caravan Accessory Belt Idler Pulley 08 Dodge G Logo
1 questions posted
Top Gates Running Experts
Gloria R. Bloomberg
Gloria R. Bloomberg
Sara Patterson
Sara Patterson
Level 1 Expert
Are you a Gates Running Expert? Answer questions, earn points and help others
View Most Popular
Gates Running
  • Gates Running
Most Popular Question
miss fire cylinder 5 random misfire
  • Running
