20 Most Recent Gates 1999 Mazda Protege Timing Belt Kit 99 Mazda Protege Questions & Answers
2answers
How to find timing when installing timing belt to
Personally, I use a paint stick to mark the original belt location. Then I take the belt off and transfer the marks to the new belt. Be sure to put a new water pump in and also a new spring on the tensioner. If you already took the beloff, then there are actually timing marks. I forget where the mark on the crank is, but it should be slightly obvious. The mark on the gear lines up with a mark on the oil pump. The camshaft gears each have 2 marks. On the front you use the one with the 'e' and the 'I' on the back. The notches have to point at eachother parallel to the cylinder head. Good luck...
11/13/2014 2:56:05 AM • Gates 1999 Mazda... • Answered on Nov 13, 2014
How does the iPod Nike running monitor work?
The Nike GPS monitor fits into your sneaker and you can track your progress on your iPhone or iPod with a special app. You can download the app from the iTunes app store.
http://nikerunning.nike.com/nikeplus/v1/pdf/English.pdf
11/25/2014 12:13:15 PM • Running • Answered on Nov 25, 2014
Can you put running shoes in the washing machine if they are air?
I have always washed my sneakers in the washing machine, if they have air bubbles make sure that you wash them on a cold wash and not too hot as this can cause the bubble to expand and rupture.
1/13/2013 12:44:04 PM • Running • Answered on Jan 13, 2013
My Nike air max bubble has burst can this be repaired?
It is unlikely that the bubble can be repaired but Nike does have a 2 year warranty depending on the wear and tear of the shoe, you could take them to the store you got them and see what they say.
1/13/2013 12:43:22 PM • Running • Answered on Jan 13, 2013
Gates 1999 Mazda Protege Timing Belt Kit 99 Mazda Protege Logo
2 questions posted
Top Gates Running Experts
Gloria R. Bloomberg
Gloria R. Bloomberg
Sara Patterson
Sara Patterson
Level 1 Expert
Are you a Gates Running Expert? Answer questions, earn points and help others
View Most Popular
Gates Running
  • Gates Running
Most Popular Question
  • Running
