20 Most Recent
JVC MX-D402T Shelf System Questions & Answers
Power failure
the 24v power connection cord in the electronic card cage may be loose. If it's not that then your power supply assembly may be shot.
Setting clock
HelloTo set clock:1. Press "Timer/clock button". The hour digit begins to flash.2. Press (<< P.DOWN or >> P.UP) on the multicontrol to set Hours.3. Press SET button. The minute digits begins to flash.4. Press (<, P.DOWN or >> P.UP) on the multicontrol to set Minutes.5. Press "Set" button."CLOCK OK" appears on the display. The clock stops flashing, and the clock timer starts from "0" seconds. If the clock is not set "AM 12:00" will flash instead of the clock indication. When the time has been set, TIMER/CLOCK can be used to operate the daily timer recording timer. If you haven't the user manaul to your set with you now, send your email address to me by Fixya comment bos. I've the downloaded user manual to your set, and I'll send a copy of it to you by return mail. OK.
Can't control volume on JVC MX-D402 system
the control knob in shelf stereos from frequent use wear out quickly. contact the manufacture and see if it would be an adventagious avenue to replace the volume control. if not to spendy.
Ryan
Please take time to rate this.
Power failure.
Try to check first your power cord,
Probably theres a cut on wire that give the flows of electricity
No stereo - one side only
You been conned, Marx. And don't you think it unwise to let such a idiot to further fiddle around with your machine?
Seek some professional's help.
I have a JVC RX-501 reciver and 2 speakers Sony(200W). I start the reciver and After 3-4 seconds it S make a sound like" bun bun " that S all... After 1-2 minute again..
The sound you're hearing could be due to a variety of reasons, such as a loose connection, a malfunctioning component, or a power issue. Here are some steps you can take to troubleshoot the issue:
Check the speaker connections: Ensure that the speaker wires are properly connected to the receiver and the speakers. Make sure that the positive and negative terminals are correctly aligned. You can also try disconnecting and reconnecting the wires to ensure a secure connection.
Check the power source: Ensure that the receiver is plugged into a working power outlet and that the power cord is securely connected to the receiver. You can also try plugging the receiver into a different power outlet to see if that resolves the issue.
Check the volume level: Ensure that the volume level on the receiver is not set too high. High volume levels can cause distortion and other issues.
Reset the receiver: Try resetting the receiver to its default settings. To do this, turn off the receiver and unplug it from the power source. Wait for a few minutes, then plug the receiver back in and turn it on.
If these suggestion don't help, you may have to seek professional repair.
2/2/2024 9:08:57 PM •
JVC Audio...
Answered
on Feb 02, 2024
1997 JVC RC-X270 does not read CDs
A bit of basic knowledge is required first;
Insert CD, the first thing the processor expects is to scheive Focus.
When Focus is acheived, the Spindle Motor will turn.
Either the Laser cannot Focus or there is an issues with the Spindle Motor.
Which is it ... if you know, then you will know which part or board has the issue.
1/29/2024 6:36:28 PM •
JVC Audio...
Answered
on Jan 29, 2024
