20 Most Recent JVC RX-778V Questions & Answers
2answers
Jvc subwoofer sx pw22 working fine then just
First check all the connections. Something as simple as a loose wire will cause your sub to shut down. If all connections are secure, then your coils on the sub itself may have come apart. To test, try pushing in the center of the sub as it is playing. If sound comes out, it's your coils.
Hope this helps.
9/20/2014 12:37:10 AM • JVC RX-778V • Answered on Sep 20, 2014
manual
0answers
I am having trouble getting
Connect it as both devices require (in their manuals), assign the digital input (as applicable).
8/14/2011 10:37:27 PM • JVC RX-778V • Answered on Aug 14, 2011
Could jvcrx 778 be converted
if it says 110/220 on the bk and there isnt a switch to change to 220 its auto but if it doesnt say 220 on there dont plug it into 220 this unit has a built in power supply so if you do 220 and its not rated for that itll fry.
1/30/2011 11:24:50 PM • JVC RX-778V • Answered on Jan 30, 2011
HOOKED ALL MY SPEAKERS UP
From the remote control ONLY:
Press MUTING to mute the sound through all
speakers and headphones connected.
"MUTING" appears on the display and the
volume turns off (the volume level indicator goes
off).
To restore the sound, press MUTING again so that "OFF" appears
on the display.
• Turning MASTER VOLUME on the front panel or pressing
VOLUME +/- on the remote control also restores the sound.
12/22/2010 2:43:14 PM • JVC RX-778V • Answered on Dec 22, 2010
Subwoofer not working.... JVC surround sound
A connectivity check could provide the solution, notice any wrong wire connections on device or any other devices requiring interconnection. The woofer would perform properly when the connections that provide current for woofing are approapiate
important notes
1. Trace the connection from Recorder or sound output to the woofer device
2. The wiring connections should be sound and video ouput into sound and video output into woofer.
3. The connections if any problems would be located at the stereo recorder or device producing the spund and video. Check the connections of wires on the recorder device ensuring rewiriing
4. finally, adjust the equalisers if any the buttoms could have been disbled by master switch hindering full blaster boost sound.
12/5/2010 9:51:37 PM • JVC RX-778V • Answered on Dec 05, 2010
I have my jvc rx-778v
There could be a couple of reasons that its overloading one is make sure that there is no bare wire touching at all.The other thing it could be is the ohms rating over your speakers may be to low for you receiver.Most receiver can handle 8 ohms to 6 ohms there are a few that can handle 4 ohms check your speaker ohms rating then check how low your receiver can handle with out going into overload.
10/19/2010 4:08:47 PM • JVC RX-778V • Answered on Oct 19, 2010
Does not turn on. no power, no lights
The first thing I would check would be fuses... they are internal so you will need to take the cover off. Make sure it's unplugged anytime you have the cover off.
4/16/2010 9:27:31 PM • JVC RX-778V • Answered on Apr 16, 2010
Used digital optical connection on amp from
pcm linear refers to how the tv is communicating with the amplifier. Follow the steps in your tv manual to ensure the tv is capable and setup for output of dolby and or dts, then try a dvd or a hd channel to test it
1/11/2010 9:45:06 PM • JVC RX-778V • Answered on Jan 11, 2010
Mute auto
I had same problem and connected antenna to fm port and it worked
1/7/2009 8:19:09 PM • JVC RX-778V • Answered on Jan 07, 2009
Sub
Most amplified sub woofers need to be grounded to the output source.If you plug the sub woofer in to the receiver you would use a ground wire from the receiver to the sub woofer there should be a ground terminal on the sub woofer and receiver.
7/28/2008 4:36:23 AM • JVC RX-778V • Answered on Jul 28, 2008
No Prologic Surround Sound
im thinking the reciever is set to get its audio from somehwere other than the dvd, sounds like you did most of the troubleshooting but do you get audio out of the reciever if its just playing the radio or something other than a dvd?
2/13/2008 10:34:52 PM • JVC RX-778V • Answered on Feb 13, 2008
0answers
Does the JVC UX-A4 have aux inputs for a separate turntable to play through amp?
It does have an aux input with two levels but this isn't suitable for a turntable. A suitable input should have RIAA correction with a sensitivity of just a few millivolts for a magnetic cartridge. Instruction manual can be found on the link below... http://resources.jvc.com/Resources/00/00/90/LVT1519-001C.pdf
3/7/2024 10:42:20 AM • JVC Audio... • Answered on Mar 07, 2024
I have jvc th a75r hardret plz help
Here is the user manual; https://www.manualslib.com/products/Jvc-Th-A75r-252593.html
3/4/2024 7:47:22 AM • JVC Audio... • Answered on Mar 04, 2024
JVC RX-778V Logo
24 questions posted
Popular Products
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Audio Players & Recorders
Most Popular Question
used digital optical connection amp from
  • Audio Players & Recorders
