20 Most Recent JVC RX-6010V Receiver Questions & Answers
3answers
My jvc rx-6010v is OVERLOADING?
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. (JVC - and others - say SIX ohms, but 8 is the "standard" you should use.) Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: The internal overload protection system you mention is designed to help prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized JVC service center must do this. Note, though, that if you have attempted to "cheat" the system several times, damage CAN be done that requires servicing.] But, before you take the unit in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
11/1/2016 10:23:56 PM • JVC RX-6010V... • Answered on Nov 01, 2016
How do I connect a turntable with RCA cables?
You can't. There is no provision for a turn table on this model receiver.
10/20/2014 4:54:24 AM • JVC RX-6010V... • Answered on Oct 20, 2014
0answers
Jvc auto mute
Be the first to answer 2/22/2014 4:08:29 AM • JVC RX-6010V... • Posted on Feb 22, 2014Be the first to answer
0answers
0answers
Dsp micon ng
Be the first to answer 1/27/2013 5:30:01 AM • JVC RX-6010V... • Posted on Jan 27, 2013Be the first to answer
0answers
Jvc rx - 6010v audio/video rec. am signal is week
Hook up a antena to it,
11/30/2012 7:41:07 PM • JVC RX-6010V... • Answered on Nov 30, 2012
0answers
0answers
0answers
JVC 6010V shows zero on volume wont go up or down
This is a fault on the D/A digital / Analogue converter , The volume control being analogue is not processing the data in the cicuit and so there is no change in the level. This can be a fault in the IC - the D/A convertor IC which is not giving any response with the turn of the potentiometer. So check this within the amplifier ONLY if you are able to trace the circuit and replace the IC connected to the potentiometer.
10/27/2011 10:24:11 AM • JVC RX-6010V... • Answered on Oct 27, 2011
I have this JVC RX-6010V
Get a microphone (with a) preamp and follow ITS instructions. It only accepts RCA Line Level analog signals.
7/5/2011 10:18:34 AM • JVC RX-6010V... • Answered on Jul 05, 2011
JVC RX-6010V Receiver Logo
29 questions posted
Popular Products
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Audio Players & Recorders
Most Popular Question
jvc rx 6010v overloading
  • Audio Players & Recorders
