20 Most Recent Lexar LDP-400 MP3 Player Questions & Answers
Hi skidney11...
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on.
6...Media player should recognize the MP3 player and sync with it.
7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Please take time to rate me thumbs up.
Lexar LDP-400... | Answered on Sep 26, 2011
You need to change your USB Port... try the back of your computer. Or you need a firmware update.
Lexar LDP-400... | Answered on Feb 06, 2010
its is because the drive is corrupted.. you need to format your mp3 only then you can acsess it again
Lexar LDP-400... | Answered on Dec 24, 2009
The Input/Output or I/O error is usually a pretty bad error on any Disk or Flash drive! It looks that this I/O error might have corrupted your media player drive directory (commonly know as FAT table).
Confirm the problem by trying to plug your device in a different USB port on your PC/Laptop: if you are still getting the I/O error, you can try to repair your player drive by using Open Windows Explorer -> Properties -> Tools -> Error-Checking facilities.
If Error-Checking cannot repair your drive, then you will unfortunately have to re-FORMAT your device Flash drive and loose everything on that drive (hope you have a good backup on your PC/Laptop)!
It is likely that the files loaded are not true MP3, therefore the PC -which can cope with WAV and other formats will play them but the player that read only MP3 cannot. Are you sure the files loaded are truly MP3?
Lexar LDP-400... | Answered on Nov 03, 2007
Formatting the Disk maybe solve it. But if the disk itself is working. Go to Start-> Run -> type "cmd" -> format F: then press "y" and another "y" if it asks you again if the system couldn't read the drive itself. Then this means that your storage on the MP3 Player (that shows as F on your computer) is now broken.
Lexar LDP-400... | Answered on May 24, 2007
What do you mean by not reconized? Does it still show up when you plug it in and just tell you its not reconized? or does it just not show anything at all? If it comes up then I suggest going to Lexars website and downloading the drivers for your LPD-400 so your computer will be able to interact with it...make sure its the mac drivers.
Lexar LDP-400... | Answered on Mar 26, 2007
Format it,, it will work.
Lexar LDP-400... | Answered on Oct 16, 2006
format your player but make a back up of your music.
Lexar LDP-400... | Answered on Sep 01, 2006
Ok will thats funny.... formatt the unit by accessing it through to my computer on your desktop , right click on my comp go to manage and then go to disk management and format it. Also try different usb port.
Lexar LDP-400... | Answered on Jun 08, 2006
Hello Lillies, it would be good if you published the exact model of your "Samsung gigantic sound system m00" and I can not interpret which would be inconvenient that you have with your Samsung
Please tell me what I'm saying, so I can help you solve the problems and you can enjoy the equipment
I wait your answer
Greetings Franco Dosil
Hola Lillies, seria bueno que publiques el modelo exacto de tu "Samsung gigantic sound system m00" y no logro interpretar cual seria en inconveniente que tienes con tu Samsung
Por favor comentame lo que te indico, como para poder ayudarte a solucionar los problemas y puedas disfrutar de equipo
Espero tu respuesta
Saludos Franco Dosil
Audio Players &... | Answered 3 hours ago
Hello Sheridan, for what you comment, you have a problem in the CD reading stage, if you have technical knowledge, with the equipment disconnected from the power network, I suggest you remove the lid of the equipment and try to access the area where find the mechanism of the CD player, this equipment has 1 CD player so it is not complicated, once located try to clean the lens of the reader with a slightly moistened with alcohol, preferably using isoprpyl alcohol, then let it dry a few seconds, carefully connect the device, turn it on and place a CD, see if it reads it, if that is the problem solved, if not, you would have to replace the laser reader or approach a specialized technical service
I hope you can solve the problem
I have attached the service manual of your Panasonic
Hola Sheridan, por lo que comentas, tienes un problema en la etapa de lectura de CD, si tienes conocimientos tecnicos,con el equipo desconectado de la red de energia, te sugiero sacar la tapa del equipo y tratar de acceder a la zona donde se encuentra el mecanismo del reproductor de CD, este equipo tiene reproductor de 1 CD por lo cual no es complicado, una vez localizado trata de limpiar la lente del lector con un isopo levemente humedecido con alcohol, preferentemente usar alcohol isoprpilico, luego de eso deja secar unos segundos, conecta con cuidado el aparato, prendelo y coloca un CD, observa si lo lee, si es asi problema resuelto, si no, tendrias que reemplazar el lector laser o acercarte a un servicio tecnico especializado
Espero puedas solucionar el inconveniente
Te adjunto el manual de servicio de tu Panasonic
https://www.manualslib.com/manual/764829/Panasonic-Sa-Akx14lm-K.html
Lexar LDP-400 MP3 Player Logo
12 questions posted
Top Lexar Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Lexar Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Lexar Audio Players & Recorders
Most Popular Question
lexar problem
  • Audio Players & Recorders
