20 Most Recent
Lexar LDP-600 MP3 Player Questions & Answers
I can download music from my PC on to the
It could be the MP3 player doesn't recognize an 8 gb card... try a smaller one
OR
The SD card could be bad... try it in another device you know suuports an 8 gb card
How do I charge the battery in my Lexas MP3 player
Just need the drivers downloaded. You can usually get them from there website. Just download the drivers, then double-click on the file once downloaded so it installs into your pc. Then restart your pc, then plug in your mp3 player and you should be good to go!
My lexar mp3 wont no longer down load. the window
Connect your player to your computer. when the computer finds your player, open my computer. Highlight your player by left clicking. Choose the folder you want to format, Usually the music folder. Next, left click and a menu will open giving you options such as format drive. a menu will open. choose to format using fat 32
I have a lock icon on my screen and the player
if you have a card on ..see if the card is locked...also try maybe is on hold position ......also it may be on hold and the button to not work ...
the other issue it might be locked with a password or some locking devise like it is in phones ..I'm not familiar with the particularly model ..but if you said that it does not appear in computer connection ..this means that is not in an accessible function.. ...
Try also to run the add new hardware and see if the computer sees it when you click added but not installed...
the issue is that it might see it ..but when it tries to get the driver from its firmware ( root folder) ...it has no access...
If you know for sure that it doesn't have a locking by password feature...this means that the hold button just crashed...and it behave by ..opening ...let you know that is in locked position ....and turn back off.. ...
INTIALIZING
Connect it to your PC and copy that file. You'll find it as one of those files Extensions
WAV SPK MP3 AAC
Need battery for Lexar LDP-600
not to be funny. but try ebay. lol or google compatible batts and then check for those on ebay. but i'm sure you'v thought of that already. just trying to help. and thanx for my feedback. it helps to confirm my thoughts
Memory loss
There is a built-in memory that saves your settings and keep the clock working while the device is shut-down.
If the device has it built-in. then it's hard to replace it.
If it could be replaced then replace it and you are good to go.
MP3 PLAYER
You have to format your storage on the MP3 Player to FAT File System.
Won't play my song.
Try formatting your storage on the MP3 Player then reset the device to the factory settings.
This will solve this problem.
Vocalizer 3 output checked cables and swapped out. 1300 watt power adaptor lights up. sound indicator light is on but no sound. tried mono and stereo. power adaptor problem?
If you've checked the cables, swapped them out, and ensured that the power adapter is providing power to the Vocalizer 3, but you're still not getting any sound output, there are a few additional troubleshooting steps you can try:
1. **Check Volume Levels**: Ensure that the volume levels on the Vocalizer 3 and any connected devices (such as mixers, amplifiers, or speakers) are turned up and not muted.
2. **Test with Different Inputs/Outputs**: Try connecting the Vocalizer 3 to different inputs on your mixer, amplifier, or speakers, and test with different output devices if possible. This can help determine if the issue is specific to certain connections or devices.
3. **Inspect Settings**: Check the settings on the Vocalizer 3 to ensure that the correct input and output sources are selected. Make sure that any settings related to mono/stereo output are configured correctly.
4. **Test with Different Power Adapter**: If you have access to another power adapter with similar specifications, try using it to power the Vocalizer 3. This can help determine if the issue is related to the power adapter.
5. **Reset the Vocalizer 3**: Some electronic devices can benefit from a reset to their factory settings. Refer to the user manual for instructions on how to perform a reset on the Vocalizer 3, and try resetting it to see if it resolves the issue.
6. **Contact Technical Support**: If you've tried the above steps and are still experiencing issues with the Vocalizer 3, it's possible that there may be a hardware problem or malfunction. Contact the manufacturer's technical support for further assistance and troubleshooting guidance. They may be able to provide additional insights or recommend repairs if necessary.
By following these troubleshooting steps, you should be able to diagnose and resolve the issue with the lack of sound output from your Vocalizer 3.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
