20 Most Recent LG LH-C6235 System Questions & Answers
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
9/3/2017 12:12:47 AM • LG LH-C6235... • Answered on Sep 03, 2017
0answers
0answers
DISC ERROR MESSAGE
Usually it helps a lot if you take off the upper case of the DVD player (7 screws) and search for the lens of the DVD/CD. Clean it with alcohol or terpentine or something like that and it will probably work afterwords. Good luck.
6/26/2010 11:50:59 AM • LG LH-C6235... • Answered on Jun 26, 2010
Dvd/cd ejects any disc installed
I have exactly the same problem. Have you found a solution?
1/26/2010 12:54:40 PM • LG LH-C6235... • Answered on Jan 26, 2010
System will play DVD's but not CD's
reset config, and test
12/22/2009 6:51:05 PM • LG LH-C6235... • Answered on Dec 22, 2009
Hello. How to set the LG DVD/CD RECEIVER LH-D6230 to the AUX mode if you have lost the remote control. Can it be done manually.
You can't. You need a remote.
Replacement remote control for LG LH-D6230
Remotes World https://remotes-world.com > LG Replacement remote control for LG LH-D6230 with all functions of original one. It replace each button of original remote control. You will receive it with ...
3/13/2024 11:40:59 PM • LG Audio Players... • Answered on Mar 13, 2024
How to remove D Protect from LG CJ45
1/24/2024 12:41:20 PM • LG Audio Players... • Answered on Jan 24, 2024
LG FB162 no sound when connected with Aux
Instead of aux (Blue Connector of PC Sound), try using head phone jack (Green Connector of PC Sound). It if is working fine, uninstall sound driver of your PC, restart PC and install sound driver again. Your problem will be fixed.
12/14/2023 2:41:16 PM • LG Audio Players... • Answered on Dec 14, 2023
How do I reset my LG LHB 625
To reset your LG LHB 625, follow these steps: Turn off the device and unplug it from the power source. Wait for a few minutes and then plug it back in. Press and hold the STOP button on the front panel of the device for at least five seconds. The display will show "INIT" and the device will reset to its factory settings. LG LHB625 Product Support :Manuals, Warranty & More ' LG U.A.E.
11/4/2023 10:38:14 AM • LG Audio Players... • Answered on Nov 04, 2023
Audio not working on VCR side of LG LRY-517 DVD/VCR combo player
The back of the lry517 has 2 sets of audio outs and 1 set of audio ins. If you are using the component video outs, use the audio outs to the right of the component outs. If you are using AV1, it should be the audio to the left of the component outs. The tape's audio may be very low, try turning up the tv volume? You could also try adjusting the tracking? Have you tried using the AV1 outputs? It would be Composite Video and stereo audio.
4/25/2023 4:29:49 AM • LG Audio Players... • Answered on Apr 25, 2023
2answers
Remote control code for LG
2/14/2023 5:45:07 AM • LG Audio Players... • Answered on Feb 14, 2023
I have a “please wait” problem in my lg home theatre (model hb906sb) ??
The "please wait" problem in your LG home theatre (model HB906SB) is likely an issue with the system's firmware or software. Try unplugging the system from the power source for a few minutes, then plugging it back in and turning it on. If the issue persists, try performing a factory reset of the system. If none of these solutions work, contact LG customer support for further assistance.
2/14/2023 5:36:07 AM • LG Audio Players... • Answered on Feb 14, 2023
2answers
How can I unlock a LG HT LHD625 to play DTS? The HT's Display recognize DTS but that is no sound.
It is not possible to unlock a LG HT LHD625 to play DTS if it does not support DTS decoding. The display may recognize the DTS signal, but if the HT does not have the necessary hardware and software to decode the DTS signal, it will not be able to produce any sound. You may need to use a different audio format or upgrade your HT to a model that supports DTS decoding.
2/14/2023 5:34:50 AM • LG Audio Players... • Answered on Feb 14, 2023
LG DVD Receiver HT552TH is not switching from DVD to AUX or Band. What to do?
Here are some steps you can try to troubleshoot the issue with your LG DVD Receiver HT552TH:
  1. Make sure that the AUX or Band input is properly connected to the receiver.
  2. Try resetting the receiver to its default settings by unplugging it from the power source, waiting for a few minutes, and then plugging it back in.
  3. Check the input settings on the receiver and make sure that the correct input is selected for the AUX or Band.
  4. Try using a different remote to see if the issue is with the remote or the receiver.
  5. If the issue persists, it may be a hardware problem with the receiver, and you may need to contact LG customer support or take it to a professional repair service.
2/14/2023 5:23:08 AM • LG Audio Players... • Answered on Feb 14, 2023
I have a LG Tribute HD. There is no option for central standard time zone anywhere. Both the network automatic time and the manual time zone s ard wrong.. I live in Topeka Ks which Time zone do I use...
Topeka, Kansas is in the Central Time Zone (CT). Therefore, you should select the "Central Time" or "CT" time zone option in your phone's settings to ensure that the time displayed on your phone is accurate for your location. If you are unable to find this option on your LG Tribute HD, you may want to try updating your phone's software or contacting LG customer support for assistance.
2/14/2023 5:19:10 AM • LG Audio Players... • Answered on Feb 14, 2023
Wat is s- protection on my lg home theater systerm
I'm not sure what specific LG home theater system you are referring to, but "S-Protect" is a feature found on some LG home theater systems that is designed to protect the system from damage due to power fluctuations or speaker wire issues. When the system detects a potential problem, it will automatically shut down to prevent further damage.
2/14/2023 5:14:06 AM • LG Audio Players... • Answered on Feb 14, 2023
LG LH-C6235 System Logo
Popular Tags
12 questions posted
Top LG Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • LG Audio Players & Recorders
Most Popular Question
dubbing from vcr dvd
  • Audio Players & Recorders
