20 Most Recent
Magic Star Karaoke Microphone Questions & Answers
I dropped the mic and
Either one of two things has happened. First, you may have unseated a wire from its solder, or the entire diapragm is damaged. I would open it up and have a look-see for any damage to the wire... If there isn't, I would send it in for service.
Microphone makes a static sound
Make sure your connections are clean and tight. There may also be an intermittant or broken wire in the cord. See if you can narrow the problem down by holding some parts of the wire stationary and moving other areas. gently shake the mike with the set off and listen closely for loose parts making noise. (The idea is to eliminate the areas that are good and what's left is broken.)
Hope this helps
