20 Most Recent
Kutop 12V intelligent LPD6803 IC 5M 150 LEDs RGB 5050 LED strip Questions & Answers
My doorbell has gone quiet
It may have this silent option in either choice for volume or melody. My doorbell has numbered buttons that need to be pressed together with the button to open the door, in order to access these functions.
Another thought is that a battery needs to be replaced.
How can I reset my floureon h 264?
Press the reset button: Using a small tool like a toothpick or paperclip, press and hold the reset button for a few seconds until the DVR resets. This will restore the DVR to its factory settings, including the default password
No sound ..Floureon 4 channel NVR Camera system...Help
- Access Menu then go to Record. Choose Parameters then Record .
- Change the Camera to where your microphone is connected (e.g. channel 1).
- Change the Stream Type to Video and Audio.
- Put a check on the box beside Record Audio. If you cannot see it, click More Settings first.
- Click on Apply to save the settings.
Have got my cctv on line but can not view cctv on laptop
If you are so sure that your CCTV is online, then you need to download the mobile app for your smartphone and configure it by using your DVR or Camera serial number, if you can view your CCTV through the mobile app, then your CCTV is truly online. In order to troubleshoot it on your laptop, you need to make sure that you install updated flash player and also install the CCTV plugin on your laptop.
