20 Most Recent W90-Ru-B Rapide Ultra Upright Carpet And Upholstery Washer Questions & Answers
2answers
Vax Carpet shampooer leaking
Check seal is clean on the water container and machine!
2/15/2023 10:45:41 PM • W90-Ru-B Rapide... • Answered on Feb 15, 2023
Not drawing water into the dirt container
You can get guide from many sites.. i know few error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered within seconds u can get the access and it's totally illustrative complete
1/28/2019 9:53:31 PM • W90-Ru-B Rapide... • Answered on Jan 28, 2019
Brush not working belt is ok
This in the automotive section and not the household appliance section....BUT.. double check to see if you have the right belt for this particular model. If all else fails, take it to a vacuum cleaner dealer and they should be glad to help you, may be as easy as mis-installed parts.
8/31/2016 1:08:51 AM • W90-Ru-B Rapide... • Answered on Aug 31, 2016
Won t pickup dirty water
blocked water pipe or motor packing in
4/7/2016 10:22:17 PM • W90-Ru-B Rapide... • Answered on Apr 07, 2016
When fillng solution tank the solution just pours out the black rubber seal at the other end. why?
replace the black rubber seal, thight the nut (if you have one)
2/25/2015 7:15:26 PM • W90-Ru-B Rapide... • Answered on Feb 25, 2015
Fitting hose
Do you mean store hose or fit for use, if its fit for use then the rapide has a small flap at the front (normally has VAX logo on it) lift gently and push hose onto it and turn to lock. if its the spray hose (smaller hand held spray nozzle) then it connects a bit closer to the washer main case on a small normally orange valve which again pushes and locks. Hover has to be in upright position for hose to suck.
2/24/2015 10:48:59 AM • W90-Ru-B Rapide... • Answered on Feb 24, 2015
Just had delivery of Vax rapdide ultra carpet washer. Trying to assemble but cannot see where the hose fits into the base?
Hi, I also have a rapid, the hose pushes and turns into the clear front were it collects the old water. There is a sprung small clear plastic flap that you gently lift up and the hose pushes gently into then turns about 90 degrees to lock in place. Its located just under the orange carry handle with VAX engraved on it. the small orange valve at the top of this is for dispersing cleaning fluid from the small hand tool that sits on the handle which again pushes on and turns to lock. But be careful when taking off as it will still have a small amount of pressure in it and will squirt a little.
2/24/2015 10:25:21 AM • W90-Ru-B Rapide... • Answered on Feb 24, 2015
My vax is spraying water out all the time and I do not have my finger on the trigger.
clean or replace switch
10/10/2014 12:03:30 AM • W90-Ru-B Rapide... • Answered on Oct 10, 2014
My vax upright rapide carpet shampooer is leaking water everywhere also the trigger on handle seems to be stuck any ideas anyone
that's your problem the trigger stuck on all the time replace trigger.
8/9/2014 11:52:54 PM • W90-Ru-B Rapide... • Answered on Aug 09, 2014
The water and solution leaks out over the left side wheel and doesn't feed to the sprayer as it should
so either the pipe is cracked or there is a missing gasket. Assuming this device was fully assembled when you received it I would check for any cracks or damage inside the containers or at the point of leakage. The best advice I would give for this is to return it if under warranty or send it to the manufacturer for servicing. If you're a serious DIYer you could disassemble it, the damage will be apparent from there.
4/26/2014 9:16:38 PM • W90-Ru-B Rapide... • Answered on Apr 26, 2014
My vax wont deliver water to the carpet when i pull the trigger
Check the delivery system for kinks in the hoses or clogs in the tank. If you need further help, reach me via phone at https://www.6ya.com/expert/scott_843b43f7ebebd3f5
4/16/2014 2:54:19 PM • W90-Ru-B Rapide... • Answered on Apr 16, 2014
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
3/28/2024 3:46:39 AM • Vehicle Parts &... • Answered on Mar 28, 2024
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
3/24/2024 2:38:44 PM • Vehicle Parts &... • Answered on Mar 24, 2024
3answers
What is hashtag
hash·tag noun
  1. (on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
    • the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
2/25/2024 9:46:45 AM • Vehicle Parts &... • Answered on Feb 25, 2024
Manual for XT-90LCD-autopage auto start
Yes
12/20/2023 6:51:49 PM • Vehicle Parts &... • Answered on Dec 20, 2023
Dynamite autopower DP-300 will not fully recharge no matter how long I leave it on the charger does not go above low charge
Hi, You need to check the output on the charger first, with a meter. Let me know and we will go from there.
10/22/2023 10:19:36 PM • Vehicle Parts &... • Answered on Oct 22, 2023
W90-Ru-B Rapide Ultra Upright Carpet And Upholstery Washer Logo
16 questions posted
Top Vax Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vax Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Vax Vehicle Parts & Accessories
Most Popular Question
water solution leaks out over left side
  • Vehicle Parts & Accessories
