20 Most Recent Linksys SD208 8-Port Ethernet Switch Questions & Answers
How can I reset?
Hi, this switch is not configurable (L2), and thereĀ“s no special reset botton, so the way to reset it is power off and power on.
6/6/2016 1:48:33 AM • Linksys SD208... • Answered on Jun 06, 2016
Port LEDs keep flashing in sequence.
The ethernet switch maybe scanning the ports for connected computers.
11/9/2012 12:25:43 AM • Linksys SD208... • Answered on Nov 09, 2012
Linksys SR224 record video.
You can't record to a network switch?? Are you thinking it is a PVR? https://www.google.com/search?q=Linksys+sr224
16-Port and 24-Port 10/100 Switches
Linksys https://downloads.linksys.com > userguide > sr2... PDF Use this guide to install the following products: SR216. 16-Port 10/100 Switch. SR224. 24-Port 10/100 Switch. 16-Port and 24-Port. 10/100 Switches. ....
5/4/2023 9:18:43 PM • Linksys... • Answered on May 04, 2023
2answers
How i do the setup of my Linksys Extender?
Unplug the power cables of the router and the range extender for 30 seconds. Plug in the router first. Wait for all the lights to be stable then plug in the range extender. Your range extender should now be in synchronized with your router.
Manually configuring a Linksys Wireless-N Range Extender
https://www.google.com/search?q=setup+Linksys+Extender ..
2/8/2022 2:18:04 AM • Linksys... • Answered on Feb 08, 2022
Frontier router
Frontier Router Login at the bottom of the Network Connections window, just below the address bar. Select Wireless Properties from the menu. Locate the Network security key field on the Security tab. You'll see your Wi-Fi network password if you click the box for Show characters.
1/28/2022 7:46:04 AM • Linksys... • Answered on Jan 28, 2022
How do I connect my Linksys router up to my existing router to stop buffering?
You can use rj45 cable to it .
10/24/2021 11:44:43 AM • Linksys... • Answered on Oct 24, 2021
2answers
How to Fix Linksys Router Error 2118?
This seems to be a symptom of a configuration error, which can be fixed by resetting the router to factory default. Do this by finding the (often partially hidden) reset button on the device, and pressing and holding down the button, with the power on, till lights start flashing on the router. Let go of the button and allow the router to reset (can take a minute or two). You will now have reset the router to factory default. To connect to your ISP, you'll need to enter your account details (and any other specific information) provided to you by your ISP. You will also have to set a name and password for the wifi section of your router (if it has wifi) if you don't want it to be freely accessible by everyone within wifi range.
7/29/2021 11:33:41 AM • Linksys... • Answered on Jul 29, 2021
Linksys WRT54G2 V1 suddenly stopped working
Disconnect the power to it, wait 5 minutes and power back on.
7/13/2021 1:37:57 PM • Linksys... • Answered on Jul 13, 2021
Why is my Linksys WRT54G wireless-g router not being recognized anymore?
just fixed one yesterday. the power pack was no good.AC wall wart, power green LED blinked endless. and the white logo, LED is dead.. a new pack fixed it. also the wrong pack used, ! do not mix them up. oops. first year 54G, v1 uses 5vdc pack. at v2, and up all want to 12vdc pack, bottom sticker on above failed was v6. you said recognized, does that mean the 4 rear Ethernet wired jacks are dead, or just wifi dead.? first the ethernet ports must work, or wifi is doomed.
2/18/2020 11:46:05 AM • Linksys... • Answered on Feb 18, 2020
How to fix Linksys router error 321 ?
Good day, This might be of help . Steps To Fix Linksys Router Error 321:- Step1:- Check the Firewall Settings To check the Firewall Settings is the first priority for the users. Then check the firewall settings of the computer/ Laptop, will be helpful to find the problem. If there is any firewall installed on the computer, so the users need to turn it OFF.During the process, the users ensure that the Local Area Connection on the computer is not disabled. The Local Area Connection should not have any static IP address assigned. If there is any then the users need to immediately set the IP address to automatic. Method2:- Run the Installation CD Again:- The users require trying to run the CD again and ensure when the CD runs, it will ask to connect the computer and the modem to the router with the cable. So the users will need to notice, that there all the lights lit up on the router. If it's not, then users will need to setup their router without the CD. The users can get the instruction to setup router manually in the method 3. Step3:- Try to Setup Router Without Installation CD Setup Linksys Router without Installation CD is another best option for users in order to completely avoid the in order to fix Linksys Router Error 321. Follow the below-given instruction to Setup Linksys Router without Installation CD: First of all, connect the main computer to the Ethernet port on the router. Then the users need to connect the modem to the Internet port on the router. Now it's time to verify the status of the light that is blinking properly. Next, users need to open the setup page of the Linksys Router and then change the Internet connection settings manually. In the setup page of the Linksys Router, the users can change the settings of the router as per their needs. Then the default IP address of many Linksys router is 192.168.1.1. And the default username and password would be an "admin". Wait for a few minutes, when the main computer is able to access the Internet, so users need to create a wireless network for their wireless computers/devices. or you can call them @ Toll Free 1-800-204-6959 that is Lynksys support.
2/3/2020 1:14:25 PM • Linksys... • Answered on Feb 03, 2020
LinkSys SuPport NuMber $1{877}*[717]*^{0727} in USA/CANADA
Setup helps
11/26/2019 11:52:55 AM • Linksys... • Answered on Nov 26, 2019
How to Set Up Linksys WRT54G Wireless G Router
The vent actuators are bad. there should be two. one on each side. they are small toy like motors that open and close the vents from within to allow the hot air to blow by closing the vents to the a/c unit.
11/21/2019 5:05:43 AM • Linksys... • Answered on Nov 21, 2019
How do i configure my linksys router for best preformance, optimum said im paying for speed but my router needs to be configured
Which Linksys model of router? What cable service? What did they say needed to be configured? https://www.linksys.com/no/support-article?articleNum=142912
11/15/2019 11:43:12 PM • Linksys... • Answered on Nov 15, 2019
LInKsYs rOuTeR sUpPoRt pHoNe nUmBeR~+1:[877]:[769]:[O969].hElP
You can get best linksys router support phone number at Toll Free Number ( 1-877-769-0969 ). Linksys router Tech Support number ( 1-877-769-0969 )
11/12/2019 5:56:19 AM • Linksys... • Answered on Nov 12, 2019
LiNkSyS rOuTeR cUsToMeR sErViCe pHoNe nUmBeR 1,{877*.SCAMMER 69*}.help
DO NOT CALL FAKE NUMBERS OR GO TO FAKE WEBSITES
11/11/2019 5:35:18 AM • Linksys... • Answered on Nov 11, 2019
LinKsYs rOuTer sUppOrT pHoNe nUmBeR $#@[1.877.769.0969].help
Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
11/1/2019 4:54:30 AM • Linksys... • Answered on Nov 01, 2019
LINKSYS tech support pHoNe #[+18OO^8O3:-1O69;-] nUmBeR USA
Laliren, Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
10/15/2019 3:15:32 AM • Linksys... • Answered on Oct 15, 2019
LINKSYS Tech support pHoNe [{+1-800/'828-0294*;-}] nUmBeR AB .
Anita, Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
10/13/2019 4:05:29 AM • Linksys... • Answered on Oct 13, 2019
Linksys SD208 8-Port Ethernet Switch Logo
3 questions posted
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Linksys Computers & Internet
Most Popular Question
rest sd208 switch
  • Computers & Internet
