20 Most Recent Compaq iPAQ MP2810 Multimedia Projector Questions & Answers
3answers
hi all... i have this projector and it boosts up flashes the blue screen and sometimes the projected image too. then goes to standby mode.
I have managed to keep it going enough to see the problem for myself. Here is what i did.. lye the projector on its left side while a cool blower blows through the left side of the lamp housing. fire it up and it will stay on. I went to the menu and did a factory reset as well as lamp hours reset. checked the lamp hours and it was at zero. so its never going to stay on for long for one reason.
As the lamps get older the emit more heat and therefore cause the unit to shutdown. so if you want it to work your going to have to order that lamp. The cheapest i found is from austrailia link off ebay below.
http://cgi.ebay.co.uk/COMPAQ-HP-MP2800-MP2810-MP-2800-MP-2810-Lamp-L1552A_W0QQitemZ280387113761QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item41485fd321&_trksid=p3286.m63.l1177
last link is for the manual found in this forum but not clear on how to get it.
http://h10032.www1.hp.com/ctg/Manual/bpj07855.pdf
Hope you get a good result bulb on order.
AndystUK
vote me happy
7/31/2014 7:06:08 PM • Compaq iPAQ... • Answered on Jul 31, 2014
0answers
Will not power up
POWER SUPPLY POSSIBLY HELD IN STANDBY FOR VARIOUS REASONS
4/18/2013 11:50:42 PM • Compaq iPAQ... • Answered on Apr 18, 2013
0answers
75.81902.001
Be the first to answer 1/26/2013 3:31:26 AM • Compaq iPAQ... • Posted on Jan 26, 2013Be the first to answer
2answers
No power to projector
Generally when the globe goes end of life and needs replacing the unit will fail to power up. Try another globe if you have one spare.
4/1/2010 7:14:50 AM • Compaq iPAQ... • Answered on Apr 01, 2010
The fuse directly is broken when the power is on
The 5 leg black plastic chip part is a "VIPer100a" I have one with the same problem, but mine burned up pcb tracks and other parts.
Good luck.
Peter
9/21/2009 8:21:39 PM • Compaq iPAQ... • Answered on Sep 21, 2009
2answers
Cannon Projector LX-V5
Hi guys
Try using a different signal cable.
If this doesn't solve your problems , you will most probably be looking a new Mainboard.
Very expensive part to have replaced , so try and get a dealer that can repair.
5/29/2009 6:46:02 PM • Compaq iPAQ... • Answered on May 29, 2009
4answers
Won't power off when pressing power button, just goes to standby mode
With most projectors you have to press the power button twice to confirm that you want to turn it off. When you press it the first time it waits for a bit and then turns itself back on assuming you hit the power button on accident.
10/16/2008 2:03:43 PM • Compaq iPAQ... • Answered on Oct 16, 2008
System shuts down
Hi labiancad
Were you able to see if all of the fans are working ?
Is there any of the LED's on the Projector flickering and what colour if they are ?
7/22/2008 2:07:31 PM • Compaq iPAQ... • Answered on Jul 22, 2008
Compaq iPAQ MP2810 Multimedia Projector turns to standby after 10 to 15 seconds
check the ventilation it might be overheating.
4/17/2008 4:15:44 AM • Compaq iPAQ... • Answered on Apr 17, 2008
No power on Compaq MP2800 Microportable Projector
I am currently struggling with this issue.
There is an easily-accessed fuse inside the projector.
I was very excited to discover this last night.
However, before you get you're hopes up (as I did) remember: If the fuse blew, something else probably went first. After buying and replacing the fuse today, I realise that I need to replace or repair the power supply as it pops the fuse every time.
Here's how to get to the fuse:
Take off the lamp.
Now, looking at the projector from the back, you need to remove the left hand side panel.
This involves taking out 2 screws from that panel, 2 from the bottom and the 2 video connector hexagonal bolt things that are also in that panel.
The panel sort of hinges off, starting from the bottom.
You will see the fuse in the bottom right corner where the power lead goes.
It is a slow-blow (time delay fuse) so get the exact same one to replace it. A pack of 10 cost me €4.19 in Maplin, Galway, Ireland.
Anyways, this did not do the job for me... the power supply set the fuses off like fireworks and also blew a few in the socket plug as well (I don't think US readers will have those)
I will let you know how I get on with the power unit....
Good luck to ye!
3/22/2008 4:24:38 AM • Compaq iPAQ... • Answered on Mar 22, 2008
Printer
Go to Control Panel look and see what printer or printers are connected to your PC. Then I would try to reinstall my new printer.
5/17/2017 4:08:06 PM • Compaq Office... • Answered on May 17, 2017
0answers
I have win.xp operating sys. trying to connect
You need the Windows XP driver for The Compaq A-1000 printer. Which is necessary as well as up so 15245 for all printer features.
5/3/2017 1:16:46 PM • Compaq Office... • Answered on May 03, 2017
Compaq iPAQ MP2810 Multimedia Projector Logo
19 questions posted
Top Compaq Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Office Equipment & Supplies
Most Popular Question
fuse directly broken when power
  • Office Equipment & Supplies
